1" tweeters in 2007 door
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icarus II, Mar 31, 2021.
  1. Mar 31, 2021 at 11:57 AM
    Icarus II
    Icarus II [OP] Well-Known Member
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Am I correct to assume the area around the tweeter should be filled to direct all of the sound into the cab?
  2. Mar 31, 2021 at 12:17 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    The frequencies they reproduce are directional by nature. Just make sure that they're not crooked when installed and you should be fine.
  3. Mar 31, 2021 at 12:34 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    The reason a speaker cones back is isolated from the front is because the sound waves from the back is opposite to the front; and so they tend to cancel each other.
  4. Mar 31, 2021 at 1:12 PM
    Larzzzz
    Larry
    MA
    I don't think I've ever seen an open basket tweeter.
    Woofers, midranges....ok. they're moving much more air than a tweeter and need access to volume behind them to operate. I've seen woofers with surrounds pushed off of the basket because they were in to small an enclosure.
  5. Mar 31, 2021 at 1:16 PM
    Icarus II
    Keith
    Southeast Pa.
    2007 Prerunner SR5
    Thanks for the verification.
