Discussion in '3rd Gen. Tacomas (2016-2023)' started by BiggiesTaco, Apr 13, 2025.
  1. Apr 13, 2025 at 7:22 PM
    BiggiesTaco
    BiggiesTaco [OP] Active Member
    San Diego
    2017 TRD OFF-ROAD 4x4 Tacoma LB
    Chiggy215 likes this.
  2. Apr 13, 2025 at 7:35 PM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    You should be able to look at the engine & find the source of the leak...
    Its not just all over the bottom side of the cab & you cant see the place of origin,
    We cant help you with this, flashlight & eyes....
    The oil filter gasket probably just shifted during removal, unless the oil filter area is totally oil soaked....
    post some pics...
    Get under it, look at timing cover, valve covers, back of the engine above the transmission, engine oil pan area, where the trans meets the back of the engine....
    People giving you advise is pure speculation without seeing it & making sense of the story which is all right there....
    You dont need to actually see it leak, you need to figure out what on the engine is actually wet with oil, thats the source of the leak...
    Need to look up high first from below as leaks travel downward.
    Oil pan can be totally soaked but could be from leaking valve covers above dripping down...
  3. Apr 13, 2025 at 11:07 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    2?
  4. Apr 13, 2025 at 11:09 PM
    MGMDesertTaco
  5. Apr 13, 2025 at 11:12 PM
    MGMDesertTaco
    Remove or pull the splash shields away in the fender area and use a flashlight.
  6. Apr 14, 2025 at 12:24 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Super Swampers are always the answer
    SR-71A, TSAVO, Steves104x4 and 3 others like this.
  7. Apr 14, 2025 at 5:58 AM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    There’s a TSB for that 1 don’t drive it take it straight to your local Toyota service department.
    TartanEagle likes this.
  8. Apr 14, 2025 at 6:02 AM
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
  9. Apr 14, 2025 at 6:04 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
  10. Apr 14, 2025 at 6:04 AM
    Squirt
    Ben
  11. Apr 14, 2025 at 6:04 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
  12. Apr 14, 2025 at 6:22 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
  13. Apr 14, 2025 at 6:32 AM
    fiftysix
    fiftysix Mell-Known Wember
    Midwest
    23 TRD OR, 03 Rust Bucket
  14. Apr 14, 2025 at 6:34 AM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    Nueve
  15. Apr 14, 2025 at 6:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    One is the loneliest number .....
    Two can be as bad as one...
    3 Dog Night
  16. Apr 14, 2025 at 7:32 AM
    eurowner
    eurowner Duke Sky
    Scoty
    8675309
    I win
  17. Apr 14, 2025 at 7:59 AM
    RDT415
    RDT415 DUCTACO
    Sonoma County
    23 TRD Pro 6MT / past 04 DCSB 4WD
    Mobil
    oldtimertoyota and 23MGM like this.
  18. Apr 14, 2025 at 8:01 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  19. Apr 14, 2025 at 8:02 AM
    lowmower
    lowmower Well-Known Member
    Benji
    2011 Pyrite Mica V6
  20. Apr 14, 2025 at 8:19 AM
    Toyko Joe
    Toyko Joe Here for the pictures
