10" 5150 shock okay?
Discussion in 'Suspension' started by Ahshiet, Aug 31, 2010.
  1. Aug 31, 2010 at 12:40 PM
    Ahshiet
    Ahshiet [OP] Well-Known Member
    Maui,Hawaii
    09 MG Sport DC 4x4
    Set #1 16x10 ion alloy wheel 31x12.5 super swampers Set#2 17x9 KMC Diesel black 305/65/17 M/T ATZ baja Set#3 TRD offroad wheels painted wrinkle black with H/T tire 275/70/16 Set#4 Weld racing 16x12 Typhoon with 305/70/16 BF KO tires Set#5 Weld racing 16.5x12 36x16 fun country Set#6 TRD rugged edition wheels 305/75/16 baja claws Set#7 16x10 procomp steel "beadlooks" 33x12.50 TSL Boggers Spider track spacers in front Wet Okole black seat covers fronts with pockets,back and armrest HIDs high Lexus projector fogs h11 hid 3500k Toyota bed mat black trd exhaust Fujita intake black Xrunner badges carbon fiber door sills Alpine double din 2 8" bazookas (modded) 2 Alpine type-r 8's in tubes Rockford fosgate 1500w silverstar blinker bulbs front and back Led lic plate bulbs Led dome light Led map lights Black eBay headlights VHT night shade tails and 3rd brake light Custom made rear fog lights(next to 3rd brake light) Sticker bombed bed walls and pass. A-pill
    Ok so I have rear stock non tsb leaf packs with 2inch blocks and stock bump stops and my tires stick out a bit so they don't stuff the fender to deep but with the block it's perfect now it doesn't rub in the rear.
    So my question is because the axle is 2 inches farther from the frame would a 10 inch rear shock be fine? Or would it still bottom the shock out?
  2. Aug 31, 2010 at 1:07 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Call Downsouth Motor sports...they are going to help you the fastest and the cheapest.
