'10 Access Cab rear speakers, idea... why not?
Discussion in 'Audio & Video' started by dblodgett, Jan 30, 2010.
  1. Jan 30, 2010 at 12:02 PM
    dblodgett
    dblodgett [OP] New Member
    Dave
    WI
    '10 Access CAB 2WD SR5
    I've been looking into upgrading my stock sr5 access cab stereo. Here's the idea...
    Leave the stock head unit, put in a 4 channel amp (any ideas where the best place to put it is?), some component speakers in the front doors, some component's in the rear wing doors.
    The rear doors are a sticking point... I've seen two methods: cut a hole and put an aftermarket grill on it, or cut a hole and put some grill cloth on it.
    Why not just drill a million holes in a pattern? If you did it right it could look totally stock. Anyone done it this way?
    What was the verdict on wiring? Are there any speaker wires going to the rear door or do you need to run new ones?
    Thanks for any advice/opinions.
    D
  2. Jan 30, 2010 at 1:53 PM
    RTaylor
    RTaylor Active Member
    Arkansas
    08 Tacoma TRD Sport
    i would do the components up front but the rear speakers are "fill" sound so doing components in the rear will be more trouble than they are worth. as for leaving the stock head unit, i would highly recommend that you go aftermarket. if you don't there will be at least 20 t-taps in your harness. as for the other questions sorry i do not know the access cabs well enough.
  3. Feb 13, 2010 at 12:40 PM
    PETEREDGE
    PETEREDGE Well-Known Member
    PETER
    TEXAS
    2012 BAJA BLACK 4X4
    ARB FRONT BUMPER...16x8 SR8 RIMS ,295 BFG KO2'S,DEMELLO SLIDERS,UPGRADED SOUND SYSTEM...
  4. Feb 13, 2010 at 1:04 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    OR your could buy 2008 rear door panels, 08's have the speakers in the doors and not in the ceiling.
