10 lbs, per tire lighter and no better MPG,,wtf..
Discussion in 'Wheels & Tires' started by bludweiaer, Nov 6, 2019.
  1. Nov 6, 2019 at 2:05 PM
    bludweiaer
    bludweiaer [OP] Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    as the title says,, just went from a 265/70/17 nitto ridge grappler E-load 54 lbs, to a 265/70/17 general grabber-at-x, 43 lbs. standard load..and see no improvement in MPG, possibly less after 3 tanks of gas.. wtf
  2. Nov 6, 2019 at 2:07 PM
    81shark
    81shark Well-Known Member
    Have you considered adding a wing to your bed?
    Shadowscoutt and tcjacado like this.
  3. Nov 6, 2019 at 2:10 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Are they inflated properly? Did you calculate it or are you going off the computer?
    uurx likes this.
  4. Nov 6, 2019 at 2:10 PM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    same experience, went from an E to a C in the same tire, same size and only gained maybe 1 mpg. Its really the tread pattern and size that effects mpg more than the weight.
  5. Nov 6, 2019 at 2:11 PM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Interesting. But maybe give it a few tanks to see more average
  6. Nov 6, 2019 at 2:14 PM
    81shark
    you cut 44lbs off of a truck that weighs ~4500 lbs. that's like less than a 1% weight reduction. Happy friday i guess.
  7. Nov 6, 2019 at 2:14 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Great question. OP read this.
  8. Nov 6, 2019 at 2:17 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    44lbs rolling should make a difference. I'm guessing it's the computer that's reading wrong. Not a true calculation.
  9. Nov 6, 2019 at 2:18 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Has to do with rotational mass, not necessary overall weight loss in comparison to the whole truck.
    Front sight, jerzsubbie and Armedine like this.
  10. Nov 6, 2019 at 2:20 PM
    soggyBottom
    soggyBottom Well-Known Member
    There was another thread like this recently. What I was trying to get in the post below is that even if your tires were 100lbs each, it's really not much.
  11. Nov 6, 2019 at 2:22 PM
    toyotatacomaTRD
    Probably because the tires were installed right around the time winter gas was switched over. That and the mental mindset behind really driving it to see how sticky the new tires are.
    ELVIS and R242 like this.
  12. Nov 6, 2019 at 2:23 PM
    81shark
    still a small change. what does the rim weigh. 25lbs??? just guessing.. so 12.6% reduction in rotating mass. i wouldn't expect much of a change unless he changed his aero package
  13. Nov 6, 2019 at 2:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Soo....whats the actual MPG difference?
  14. Nov 6, 2019 at 4:50 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    40lbs means nothing. Come on guys. If we went by that premise. Every time you put you 100lb wife in for a road trip your mileage should go to crap. 40lbs means nothing.
    jon_elc likes this.
  15. Nov 6, 2019 at 4:51 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That’s a bad comparison because the wife isn’t unsprung rotational weight
    Chadr7858, revtune, dusman and 3 others like this.
  16. Nov 6, 2019 at 4:55 PM
    gotoman1969
    I know everyone talks about rotational weight, it makes a difference at get up to speed but once rolling mass is moving it keeps it inertia much easier, it harder to slow down but at speed it wants to keep moving so it actually helps. But all in all 40lbs isnt magically giving you 2-4mpg.
  17. Nov 6, 2019 at 4:58 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Try two experiments.
    First pick your wife up, hold for one minute and then put her down.
    Next, pick her up and spin her at 500 RPMs for one minute. Then stop and put her down.
    Are these the same thing? Which one is harder.
  18. Nov 6, 2019 at 4:59 PM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    Not yet
    SmokeyTacoAZ likes this.
  19. Nov 6, 2019 at 5:00 PM
    cpc
    cpc Well-Known Member
    MASS/ESSEX COUNTY
    TRD PRO
    cbi front receiver, rigid lights, leitner designs, mobtown sliders, Brute Force Fab
    40 lbs. of unsprung weight is not the same as 40 lbs. cargo. Try running with heavy boots then try running with track shoes, more energy would be expended with the boots.
  20. Nov 6, 2019 at 5:02 PM
    jowybyo
    Joe
    Baltimore, MD
    Driving a 4banger, I can tell you that it has a harder time keeping those damn things rolling. The road isn’t a perfect frictionless physics homework problem. The road has small hills and turns all which cause continuous acceleration.
    revtune, lojack and 0xDEADBEEF like this.
