10 month old frame, Rust showing!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by oliverlove, Jun 1, 2011.
  1. Jun 1, 2011 at 5:09 PM
    oliverlove
    oliverlove [OP] Well-Known Member
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    So guys I need some advice. I purchase my 2001 taco about 10 months ago. The frame was brand new at that time. The dealer replaced it during the buyback from the last owner. Since that time I have moved 2000 miles(from NH to TX) from the place I bought it. There is rust showing through on the frame at most of the welds. It stains the paint in some places and has broken through in others.
    On the body itself around just about every drain-hole, bolt, and fitting there is rust.
    WTF?!
    Is this normal????
  2. Jun 1, 2011 at 5:31 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Damn. You sure they did a frame replacement and not just a coating? Either way I'd be throwing a fit and sending pictures to Corporate Toyota. Tsunami in mind...
  3. Jun 2, 2011 at 3:57 AM
    oliverlove
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    I'll take some this afternoon and post them up.
    I know they replaced it! The warning stickers for team lifting and all that crap are still on the frame!
  4. Jun 2, 2011 at 4:03 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Might have something to do with the salty air around where you live since it's right by the beach.
  5. Jun 2, 2011 at 8:21 AM
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    how much "rust" is there, post up some pictures
  6. Jun 2, 2011 at 8:24 AM
    xxaarraa
    xxaarraa Well-Known Member
    Call Toyota, they will most likely work something out with you. But also keep in mind that its a 12 year old truck. Some rust is to be expected especially if you bought it in the North East.
  7. Jun 2, 2011 at 8:37 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    The frame = 1 yr old or less per 1st post..........
  8. Jun 2, 2011 at 11:54 AM
    xxaarraa
    He also complains of rust in body/cab.
  9. Jun 3, 2011 at 4:46 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    WI
    2021 TRD OR Premium 6MT
    I'd like to see some pictures as well. I've seen some surface rust even on brand new trucks on the dealer lot, depends on what it is.
