10" or 12" shocks cons/pros?
Discussion in 'Long Travel Suspension' started by alexplb, Apr 14, 2019.
  1. Apr 17, 2019 at 2:30 PM
    alexplb
    alexplb [OP] Well-Known Member
    No I’m saying I agree. Someone was saying that spending 15-16k isn’t needed to get a very well performing set up but what you’ve said earlier pretty much puts me right back at the price point you’re talking about anyway so either way you spin it it will cost over $10k for any set up that is able to perform better than bolt on mid travel market
  2. Apr 17, 2019 at 8:18 PM
    alexplb
    I agree there are a ton of fab shops but doesn't mean they know suspension beyond being able to install it... Getting it to fit and welded on is just part of the job as you know. Knowing who to trust is the difficult part, everyone will take the money gladly but doesn't mean they will deliver. just for kicks I got the quote from DMZ... jaw dropped nearly $20K for TC 2.5 racer front/rear set up unbelievable !
  3. Apr 17, 2019 at 8:20 PM
    alexplb
    what is your set up are you running heavy or pre runner set up ? Curious what is your impression of how the truck handles now going from what I assume stock?
  4. Apr 17, 2019 at 10:36 PM
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
    Listen OP, you have just gotten advice from one of the best guys for mid travel setups, granted because he makes his own kit for TW members. These shops...
    don't charge you however much money just because they want to. It is because they are reputable shops that build long travel trucks that take more abuse than your pots and pans sliding around in the back of your camper. Let's look at it this way, you say you have a STEEL front, rear, and full skids. w o w. prob like 400+ lbs. A vagabond drifter, I don't even wanna guess how much that weights. You are already prob 700+ lbs, not including gear. Like those who have said before, you have to pay to play or shave the weight.
  5. Apr 17, 2019 at 10:51 PM
    alexplb
    400 lbs I wish... I probably have that in bumpers alone. Habitat thats another 350 lbs gear, fridge, battery, racks, sliders, armor etc I'm guessing is easily another 500 -700 lbs. The question is does the long travel conversion able to handle overland set ups/weight or is it a pipe dream. All things considered I'm simply wondering if it's the right choice that's what it comes down to.
  6. Apr 18, 2019 at 9:47 AM
    Canks
    Canks Well-Known Member
    San Diego
    08 DCSB in pieces; 04 Tundra Access cab also in pieces
    Weight isnt the problem, tuning is. Very high end prerunners weigh in 7-8k lbs and they will boogie through things that will make you piss in your chonies. You will need to get your spring rates and valving correct to your vehicle. 99% of people do not understand this and more importantly do not want to do the work to get it right. Do not underestimate the work, to get it right you will have your shocks off many many many times before you are happy.
    alexplb[QUOTED][OP] likes this.
  7. Apr 18, 2019 at 10:43 PM
    alexplb
    Have you guys had experience between running a set up with shackle drop / hanger vs stock ? Wander if someone would share their experience with pros and cons
  8. Apr 23, 2019 at 11:35 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    What's a shackle drop?
    desertjunkie760 likes this.
  9. Apr 23, 2019 at 10:29 PM
    alexplb
    that was a mistype
  10. Jun 4, 2019 at 5:37 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’m no suspension expert in the slightest but I’m aware the bp-51s come with rebound and compression adjustments. Have you tried messing with that? It may take a quite of bit of time to get ballpark to your liking but that’s better than spending a chit load of money and downtime on your truck.
  11. Jun 4, 2019 at 10:19 AM
    alexplb
    Of course I’ve messed with that :) all the adjustments in the world can’t comoare to a bigger volume shock when it comes down to it. I’ve already decided and am in a process of long travel conversion. Bps will be for sale shortly.
  12. Jun 4, 2019 at 10:21 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Ok cool didn’t know. What setup are you going to go with?
  13. Jun 4, 2019 at 10:28 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    o_O :confused:
  14. Jun 4, 2019 at 1:04 PM
    alexplb
    a lot to list but rear will have leaf under with triple by pass 12” kings and shock relocation brackets as well as shackles and King hydraulic bumps. Front is total chaos +2 dual shock set up with total Chaos sway bar
  15. Jun 4, 2019 at 1:05 PM
    #35
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    Badass
  16. Jun 4, 2019 at 1:09 PM
    #36
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Am i wrong in thinking that it’s probably a bad idea to spend a ton of money for a “long travel go fast” rear end SUA setup if you still plan to keep all the heavy camping stuff on the truck? Doesn’t make a ton of sense to me but I know guys do it all the time
    mynewtoy and BVita like this.
  17. Jun 4, 2019 at 1:10 PM
    #37
    tetten
    Andy
    Socal
    :rofl:
  18. Jun 4, 2019 at 3:21 PM
    #38
    tetten
    Andy
    Socal
    If you pay close attention you'll notice anyone that has a SUA camping truck keeps it relatively lightweight. There's a reason people don't run armor, swing gates, shells/RTT, Jerry cans, fridges, and other heavy ass camping shit on SUA.
  19. Jun 4, 2019 at 3:52 PM
    #39
    alexplb
    Different ways to skin a cat most guys don’t go to that set up mainly because of $$ and who said you can’t go fast with a bit extra weight ? Have you seen semi trucks and what they do with Baja racing ? Lol
  20. Jun 4, 2019 at 3:55 PM
    #40
    alexplb
    I promise it will make some sense in along run .... maybe lol
