10" sub not fitting in 10" enclosure
Discussion in 'Audio & Video' started by JoshLV, Feb 1, 2011.
  1. Feb 1, 2011 at 9:39 AM
    JoshLV
    JoshLV [OP] Well-Known Member
    Josh
    Hanford, CA
    2007 Tacoma SR5
    So I ordered an enclosure for my single 10" pioneer champion pro sub. Its supposed to fit all 10" subs. But when I set my sub down into it, it still has about an inch left until its fully seated. If I screw it down, with that space there, will I encounter any problems??
  2. Feb 1, 2011 at 9:42 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Ya ur gonna need to make the hole bigger. Can be done with basic tools if you got em.
  3. Feb 1, 2011 at 9:44 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well is the hole not big enough or is the sub hitting the back of the box? And NO! do not screw it down until it's fully seated in the box.
  4. Feb 1, 2011 at 9:48 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    The hole needs to be bigger because its not letting it sink down enough. Also, 2 sides of the sub hit the notch on each side of the box. 10" my ass. The depth is fine it still has room in the back.
  5. Feb 1, 2011 at 9:59 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
  6. Feb 1, 2011 at 10:03 AM
    JLee
    Jerry
    Benicia, CA
    Yeah your mounting depth is fine your just going to have to shave at little at a time until the sub fits.
  7. Feb 1, 2011 at 10:05 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Ah that pisses me off. Just use regular sand paper sheets or what? I don't wanna make it uneven so I'm guessing it will take awhile..
  8. Feb 1, 2011 at 10:06 AM
    btuner
    btuner <<<<>>>>
    Brandon
    Hendersonville NC
    09 PreRunner SR5
    Stage III TRD Badge
  9. Feb 1, 2011 at 10:09 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    No I'm just on my phone so I found the first link.
  10. Feb 1, 2011 at 10:12 AM
    JLee
    Jerry
    Benicia, CA
    Well a wood file would be faster just make sure your taking off the wood evenly take your time and it shouldn't be that hard. If you don't trust your self with a file get some 50 grit sand paper and sand it by hand.
  11. Feb 1, 2011 at 10:19 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    You'll be there for a month with sandpaper. I've had to deal with this problem a bunch of times....Peel/cut some of the carpet back and use a jigsaw, the hole doesn't need to be perfect/pretty you just need it to be sealed. Jig will work just take your time.
  12. Feb 1, 2011 at 10:23 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Go buy a rasp. Like $5 and it will save you a month.
  13. Feb 1, 2011 at 10:24 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Hmmm. Considering I have no tools ill probably just go buy a file.
  14. Feb 1, 2011 at 10:26 AM
    Daudio
    North Jersey
    '02 SR5
    rethink that depending on how much you have to take off. If you don't have a jig do what ^ he said. Rasp will work better then a file.
  15. Feb 1, 2011 at 10:28 AM
    JoshLV
    Josh
    Hanford, CA
    2007 Tacoma SR5
    Can I get a rasp at home depot? Never heard of it.
    Edit: ah scratch that. I know what that is just considered it a file.
  16. Feb 1, 2011 at 12:19 PM
    ItalynStylion
    Steven
    DFW, Tx.
    Yeah I got mine at HD. Mine has a file on the back and a rasp on the other side.
  17. Feb 1, 2011 at 12:21 PM
    JLee
    Jerry
    Benicia, CA
    My bad I meant rasp
