100,000 mile service
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacofromcolo, Jun 17, 2011.
  1. Jun 17, 2011 at 9:48 AM
    Tacofromcolo
    Tacofromcolo [OP] New Member
    Fort Collins
    95 4x4 v6
    Hey guys, new here. I have a 95 Taco 4x4 V6 with 104K mi. I want to invest some money in keeping this truck. I have never done any work on it other than basic maintenance. I want to service it now with a clutch and timing belt.
    Is there anything I need to be aware of in changing out these things? Also, what else should I look at?
    thanks, :burnrubber:
  2. Jun 17, 2011 at 9:52 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Change the water pump while your changing the timing belt. I would also change out the differential fluid in the front and rear as well as the transfer case and transmission if you haven't done that recently.
  3. Jun 17, 2011 at 4:40 PM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    I did something similar: the timing belt had been replaced, so I left that alone: I did the following for my major tune: replaced all belts, adjusted the valves (checked them), full lube on the drivetrain, checked the carrier bearing, replaced all fluids with synthetics (saved almost 2 mile per gallon with that one), switched out my starter contacts, replaced the fuel filter and checked the wheel bearings/brakes.
    Good to go. Enjoy your almost new truck!
  4. Jun 17, 2011 at 4:42 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    x2
  5. Jun 17, 2011 at 5:13 PM
    Tacofromcolo
    Fort Collins
    95 4x4 v6
    Thanks for your expertise guys, I cant wait to get my truck new again...woohoo! :wave:
