100 octane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rangejeep, Sep 6, 2008.
  1. Sep 6, 2008 at 11:35 AM
    rangejeep
    rangejeep [OP] Well-Known Member
    Charlotte, NC
    05 Tacoma 4x4 TRD Off Road
    As anyone used 100 octane fuel in a taco with the 4.0 v6? They call it racing fuel. Texaco down the road sells for $6.99 a gallon if you're wondering.
  2. Sep 6, 2008 at 11:41 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I took my taco to my local track one day and put 100 in. I got from the airport I fly out of. It is cheaper at the airports but still expensive... like $5.75 was the best I ever saw it.
    I wouldn't use it normally though. Not worth it.
    It will put out a few more hp's but other than that nothing special.
  3. Sep 6, 2008 at 11:43 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    21 gal X $6.99 = $146.79. LOL!
    Great for track use, though.
  4. Sep 6, 2008 at 12:00 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    $7.759 X 21 gal = $162.939. Yikes.
  5. Sep 6, 2008 at 2:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hell yeah!!!! that 112 would clean out the entire fuel system really good!!!:D
  6. Sep 6, 2008 at 4:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Keep in mind, the higher the octain rating, the lesser specific energy the fuel has. At some point there will be diminishing return. I would think that would be around 95 Oct. for a N/A engine, unless it has a HIGH comp. ratio, i.e. 14-1 or so. JMHO. :)
    FWIW, I ran some 105 oct. in my boosted 2000 Tacoma, and with 32" AT's first gear spun them like I was in neutral. :D
  7. Sep 6, 2008 at 4:25 PM
    shootermcgavinyo
    shootermcgavinyo Well-Known Member
    Rockford, IL
    '08 double cab 4x4 v6 trd off road
    On an N/A engine it's pretty much a waste of money and you're not going to notice a difference. Unless your compression and timing are adjusted for it I wouldn't bother.
  8. Sep 6, 2008 at 6:54 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Is the race fuel leaded or unleaded?
  9. Sep 6, 2008 at 8:07 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Should be unleaded, leaded would cause some problems with prolonged use. Love the smell of race fuel.
  10. Sep 6, 2008 at 8:14 PM
    NHinAK
    NHinAK Active Member
    Anchorage
    08 Tundra TRD
    -Debadged
    I use Sunoco 104 UL with every tank. Runs good.:)
  11. Sep 6, 2008 at 8:16 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Fat Tuesday on South Street has 190 Octane.
  12. Sep 6, 2008 at 8:18 PM
    NHinAK
    Anchorage
    08 Tundra TRD
    -Debadged
    The use of leaded fuel will clog the CATS and sensors. It shouldn't be used. That includes anything "low lead" that you might get at an airport (AVGAS).
  13. Sep 7, 2008 at 5:46 AM
    91r100gs
    Dan
    Kansas City area
    I asked this question because I have a older Motorcycle that would love a taste of leaded gas. Just a cup full in each tank would really help protect the valves. Have not been able to find any in the KC metro area. If any of the KC members know of a location, that info would be greatly appreciated. Lead substitute just are not the same.
  14. Sep 7, 2008 at 8:16 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    2012 PreRunner TRD Sport DC LB
    Undercover toneau
    As Chris mentioned, octane doesn't make power. It just makes gasoline less explosive so it doesn't destroy high compression or radically timed engines. If your engine pings you probably need more octane. If it doesn't you're wasting money buying it.
    The exception, of course, is on engines with electronic knock sensors, and I don't know if the Tacoma has these. Those engines will back off the timing if the engine pings, and so will certainly perform better with more octane (than whatever amount is allowing the engine to ping.).
    In the old days you'd buy high octane once in a while just because it also contained additives that would help clean water and crud from the fuel system. Regular gasolines didn't have them.
    Nowadays, with the wide adoption of fuel injection, I believe that virtually all gasoline sold has some of these additives.
    Anyhow, does anyone know if the Tacomas have electronic knock sensors on the engine?
  15. Sep 7, 2008 at 8:32 AM
    lawnrevenge
    lawnrevenge Well-Known Member
    Southern California
    08 regular cab 5-lug, automatic
    taken from geneberg.com
    Looks like Toyota is putting knock sensors in the Camry v6 and the v8 trucks/suvs but not in the Tacoma. My last car (VW GTI 1.8T) had a knock sensor and if I dared run regular it retarded the timing and eliminated almost any boost. Felt like I was driving a low compression POS. But unless I remapped the computer it would not increase boost or timing beyond what it did at premium. It's a huge waste of money unless as said before you're running a blower and can adjust boost and timing.
  16. Sep 7, 2008 at 8:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, they do have knock sensors, and the newer 1GR-FE engine sees a good increase in h.p. and Tq. from 91 oct. fuel. Also, Federal requirements for gasoline require that ALL grades and brands of fuel have a min. amount of addatives. In my findings, these requirements negate the use of "Off the shelf" addatives. :)
    Taken from Wiki......The 1GR-FE is the 4.0L version. ....... Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane.
  17. Sep 7, 2008 at 8:42 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    Thats one of the cheapest and most effective power boost.
  18. Sep 7, 2008 at 8:42 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  19. Sep 7, 2008 at 8:43 AM
    Caddmannq
    Caddmannq MotoNerd
    California
    Undercover toneau
    Hmmm..not that much of an increase really. I kind of doubt I'd notice the difference in my daily driving.
  20. Sep 7, 2008 at 8:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes it is. :) And in my testing I have ganed 1 to 2.5 mpg depending on driveing conditions. A much better improvement than any CAI I have found.
    *note* I havent tested the URD intake, but have heard from many people that hav them that they DO show a good gain in performance. :)
