1001 ways to lift our Tacos. Impossible solution...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FreshMexicanTaco, Mar 18, 2017.
  1. Mar 18, 2017 at 2:39 PM
    FreshMexicanTaco
    FreshMexicanTaco [OP] The Taco Garage
    AJ
    San Diego
    2019 spiced up Taco with guac, no onions.
    Dashtop Multi-Mount!, Pro grille, snug top, Kings BFGs, Front and rear view camera anytime, CMC, prinsu and more to come!
    Just recently I put wheels and tires on my truck and I have a little bit of rub, it is very very minimal but annoying non the less, so im going to have to lift the truck ( I was going to anyway but not yet)
    Again I started doing research an it turns out it is super hard to exactly know what kind of lift you are going to get from whatever kit you buy because of the million different variables that play into this.
    The point is that we all use different shocks, struts, coils, spacers, leafs, blocks and we all have different trims with different equipment installed. And... suspensions settle so you never know whats going to happen.
    I find it very hard if not impossible to know exactly how much lift each combination will give or how much it will settle, BUT!... BUT!...
    There are so many of us here that I believe if we pooled all our data together somewhere (hint hint) we should be able to get a very good idea of how much lift you gan get from every combitation of shocks and coils or leafs.
    All this information is already on here, except it is buried in thousands of different threads discussions and messages. I believe we can have a more elegant solution.
    I want to make a chart and graph that shows the most common combinations of springs and shocks and how they affect the lift amounts in different trims of our trucks.
    I have a 3rd gen TRD OR DCLB and I'm getting 5100's pretty soon so im going to start with that.
    For now I will start the chart for 3rd gens with my info and I ask everyone and anyone who is willing to pitch in to simply reply with the following info:
    Year: '16, '17 etc...
    Trim: SR, SR5, TRDOR, TRDS, Limited, Pro
    Cab & Bed: AC, DC, SB, LB
    Drive: 4x2, 4x4
    Engine: 6 or 4
    Coils (front): Stock or Aftermarket (specify)
    Shocks (front): Stock or Aftermarket (specify)
    Spacers: Size (if any)
    Leafs (rear): Stock or Aftermarket (specify)
    Shocks (rear): Stock or Aftermarket (specify)
    Blocks: Size (if any)
    (EDIT: Trying to steer away from turning this thread into a tire fitment war:duel:)
    epluribusunom likes this.
  2. Mar 18, 2017 at 2:43 PM
    epluribusunom
    epluribusunom Well-Known Member
    Luke
    '16 White SR5 4x4
    I like this idea. But it is well documented that the biggest tire you can run stock is the 265/70/r17. Get them bilsteins on!
    *Edited to 265/70/r17 realized I made a typo.*
  3. Mar 18, 2017 at 2:45 PM
    FreshMexicanTaco
    AJ
    San Diego
    The real purpose of this is to have the lift information in a centralized easy to read format, not really to solve my lift problems. I will take suggestions though.
  4. Mar 18, 2017 at 2:51 PM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    The problem is you have guys that are gonna argue their asses off over what fits and what doesnt. Then youll have the guys with TRD pros that think and claim they can run 33s without a lift. Its all over the place really. Also not all tires are exactly the same so you could have all the same specs., but the different branded tire has shorter sidewall lugs or more and they effect the situation you have displayed in your picture.
    That being said, i appreciate your enthusiasm and hope it is fruitful. More information is always good for the mind.
    FreshMexicanTaco[OP] likes this.
  5. Mar 18, 2017 at 2:52 PM
    epluribusunom
    Luke
    '16 White SR5 4x4
    I agree, there are multiple threads, however it does take a lot of looking to get any useful information. I attached a guide for the OME coils, and for the bilstein 6112's. I found them tremendously useful
    They are courtesy of Marie at Headstrong Off-Road
  6. Mar 18, 2017 at 3:01 PM
    FreshMexicanTaco
    AJ
    San Diego
    Thanks for that @epluribusunom. I expect real world data to come close to this, but I also hope I can gather even more data on more combinations and even more detailed data to share with everyone. Feel free to pitch in :bucket:
  7. Mar 18, 2017 at 3:04 PM
    uhplifted
    uhplifted The Hopfather
    Brian
    Huntington Beach, CA
    16 DCLB OR
    Did your alignment tech put your caster all the way up? That might be why. I have a dclb off road too and had 265/75/16 when I was stock and had zero rubbing.
    smitty99 likes this.
  8. Mar 18, 2017 at 3:05 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Trimming would be easier and cheaper than lifting and would have less impact on your ride quality and driveline components.
  9. Mar 18, 2017 at 3:14 PM
    FreshMexicanTaco
    AJ
    San Diego
    Agree, I might just remove the mud flaps but also I would probably set 5100 to just level, not max lift.
  10. Mar 18, 2017 at 3:39 PM
    smitty99
    Scottsdale
    Even with a lift you may still rub
  11. Mar 18, 2017 at 3:45 PM
    FreshMexicanTaco
    AJ
    San Diego
    It will when the suspension is compressed and I'm turning at that same angle. But that will happen a lot less often.
  12. Mar 18, 2017 at 7:24 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Do realize with every bit of info about peoples actual trucks and measurements theres still a ton of variables. Whats the alignment settings? Wheel offset? How much cargo? Full tank or empty tank of gas. When you say no rubbing do people actually mean through motion will not rub? Or the trip from tire store to starbucks didnt cause rubbing? Gl with your search for knowlege op, but know there is roughly zero percent chance you will find the info you seek. Better to gain a better understanding of suspension and vehicle dynamics and apply what you know
  13. Mar 18, 2017 at 9:05 PM
    RBfastback
    RBfastback It's Got Electrolytes
    mike
    FL
    16 mgm TRD off road
    i've got the dcsb OR with 265/75/16 duratrac's and had bad rubbing when turning the wheels to where the edge of the tire is closest to the fender liner and hitting brakes or accelerating.
    stock alignment with 1.25 spacers
  14. Mar 18, 2017 at 9:07 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    You're forgetting tire scrub lines, maybe.
  15. Mar 18, 2017 at 9:12 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    What a lot of people don't understand on this forum is that lifting doesn't necessarily solve rubbing issues, your wheel wells are the same size. Trim fenders/cab mounts, get better clearance bumpers, change tire size, to eliminate rubbing.
  16. Mar 18, 2017 at 9:15 PM
    T4RFTMFW
    Don't forget frame mods and firewall cutting when expo is life.
  17. Mar 18, 2017 at 9:17 PM
    the_dau
    the_dau Well-Known Member
    Vancouver BC
    2017 Inferno TRD OR DCSB
    I have a stock off road, 265/70 r17 rubs VERY SLIGHTLY at full lock, on a downhill. (basically majority of the vehicle weight has to be on the affected corner)
  18. Mar 18, 2017 at 9:50 PM
    uhplifted
    Brian
    16 DCLB OR
    There's your issue. Why the fuck are you running spacers on a 265/75? Take that shit off.
  19. Mar 19, 2017 at 7:21 AM
    FreshMexicanTaco
    AJ
    San Diego
    Well... this is going exactly as I didn't plan it...
  20. Mar 20, 2017 at 8:57 PM
    RBfastback
    mike
    FL
    16 mgm TRD off road
    because it looks amazing and i barely had to cut that much fender liner to make it stop rubbing.
    also i hate the look of wheels that are sunken in the weel well, i think it looks like shit when there flush or poking a 1/2" also i plan to do a lift uppper, UCA's and cmc anyway to fit larger tires down the road.
    i honestly didn't read anywhere that just putting the 1.25 spidertrax with 265/75 would make it rub, but it's not that bad at all.
    down the road when i get different wheels ill take them off.
