100amp Distribution Panel Negative Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Greatwhitewing, Feb 28, 2025.
  1. Feb 28, 2025 at 5:34 AM
    Greatwhitewing
    Greatwhitewing [OP] Well-Known Member
    Mass
    2022 SR5 V6
    Adding a 100 amp Blue Sea 12 circuit distribution panel and their Circuit breaker in the engine bay. I will probably never use a fraction of that capacity but it's there and want to wire it correctly for future add ons like lights, audio, winch etc.
    My primary question is do I need to run the negative from the dist panel to the battery directly or is picking up a convenient ground adequate.
    Part 2 of the question is should I connect to body/chassis or engine/tranny?
    Going to get premade 4 AWG cables with lugs. Two short positive and one negative cable
  2. Feb 28, 2025 at 7:22 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I ran my 80A to a bus bar and then 4ga to the negative terminal from the bus bar and ran new grounds to the chassis and engine block. I go through a lot of water so I wanted a little more corrosion resistance on the terminals.
  3. Feb 28, 2025 at 7:35 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Can I assume it was an exposed bus bar being a chuck of metal (copper) with tapped holes?
    I don't plan to go through a lot of water aside from the salt spray I get in New England
  4. Feb 28, 2025 at 7:55 AM
    airforceb2cc
    Don
    KCMO
    Brass marine bus bar. No corrosion in two years so far
  5. Feb 28, 2025 at 7:59 AM
    shaggy135
    shaggy135 Well-Known Member
    Valley of the Sun, AZ
    2019 Barcelona Red TRD 4x4 OR DCSB MT
    When I was running mine, I connected the negative to this ground point:
    Never had any problems. I was using 8 of the 12 circuits too.
  6. Feb 28, 2025 at 8:05 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Convenient ground is adequate. Go to the body because the battery ground is connected to the body.
  7. Feb 28, 2025 at 8:09 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Awesome reply since you answered a question I didn't even ask yet regarding interference with added hood struts. That is the same bracket I am still waiting for on a truck somewhere. Looks like you had to notch the bracket.
  8. Feb 28, 2025 at 8:12 AM
    shaggy135
    Ya, I got that back in 2020 so it was a first gen thing. The new model looks like they upgraded it and now there is a notch. I also have a standard trans so I had to relocate my clutch reservoir.
  9. Feb 28, 2025 at 11:29 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    A 100A panel won't be anywhere near enough for a winch...best practice is direct to the battery with a cutoff switch on the positive side.
    Greatwhitewing[OP] likes this.
  10. Feb 28, 2025 at 11:35 AM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Who is the maker of that bracket?
  11. Feb 28, 2025 at 11:35 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    Understood, thanks. Haven't looked at the winch option more than how much I would have to hack up my existing plastic parts and not the electrical part. Not sure I want one or would use it enough to justify the cost assuming over $1k for something decent.
  12. Feb 28, 2025 at 11:37 AM
    shaggy135
  13. Feb 28, 2025 at 11:37 AM
    Greatwhitewing
    Mass
    2022 SR5 V6
    MARSHBUSTER[QUOTED] likes this.
  14. Feb 28, 2025 at 11:38 AM
    MARSHBUSTER
    Jim
    Alamogordo NM
