100k DC with vibration
Discussion in 'Suspension' started by dakarm34, Sep 8, 2010.
  1. Sep 8, 2010 at 9:50 AM
    dakarm34
    dakarm34 [OP] Member
    RJ
    Clemmons, NC
    06 SR5 DC
    I have an 06 SR5 doublecab that has a vibration at 62-67 mph. I've had the wheels/tires balanced more than once to ensure that they are balanced, and that the rims are straight. One other thing, I've replaced one of the front half shaft axles with an aftermarket. Could it be possible that this axle isn't balanced? Could it be something else such as the rear driveshaft center bearing? Any help/suggestions are very much appreciated.
    Thanks
    RJ
  2. Sep 8, 2010 at 11:31 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    Can you feel the vibration in the steering wheel? If so you might want to rotate the tires and see if it goes away.
  3. Sep 9, 2010 at 2:55 PM
    dakarm34
    RJ
    Clemmons, NC
    06 SR5 DC
    Yes, I can feel it in the steering wheel. I'll rotate them and see. Thanks for the reply.
  4. Sep 12, 2010 at 2:33 PM
    mikemataa
    mikemataa New Member
    Did that work? I think I have the same vibration.
  5. Sep 12, 2010 at 2:34 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Its might be the U-joints in your drive shaft...thats what was causing my vibs
    The trucks in the shop as we speak getting its driveshaft re-built
