100K Maintenance Priorities
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Oct 17, 2017.
  1. Oct 17, 2017 at 11:10 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Hey guys and gals,
    I just cracked 100k and I want to give my 2009 access cab 4x4 some TLC. I'm going to chip away at necessary things as I can afford them. What would you recommend in order of priority?
    Radiator Flush?
    Differential Fluids?
    Transmission Flush?
    Power Steering flush?
    Brake fluids?
    Spark Plugs?
    Thanks!!
  2. Oct 17, 2017 at 11:21 AM
    roytown
    roytown Well-Known Member
    2015 4x4 DCSB TRD OR
    King 2.5s, Total Chaos UCA, OME springs, BAMF sliders, C4 rear bumper, Pelfreybilt IFS skids and front bumper, Baja pro and sport lights, teq custom headlights, Katzkin leather seats.
    Sounds like you got a good idea of what needs to be done.
    I'd add: Transfer case and front diff fluid change, lubing your chassis and drive line and I'm strange and like to use silicone lubricant to lube and clean the power windows (the window seat) and all key ports (door and ignition).
    I purchased my 09 at ~103,xxx and have slowly done this in order:
    Brake pad replacement
    Spark plugs, cabin and intake filter.
    Oil and filter change, drive line lubed, windows/doors lubed
    Front/rear diff & transfer case fluid change (replaced crush washers too)
    At the moment I'm getting everything I need to do a transmission pan drop and refill fluid (maybe replace the filter in there)
    Then on to coolant flush & replacing the water pump, pullies, tensioners, belt, hoses and thermostat.
    I can't say that I have good information as to which is more important as I am just doing it as I can afford it ASAP.
    2009Access4x4[OP] likes this.
  3. Oct 17, 2017 at 11:27 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Don't forget the serpentine belt, it's easy to do and takes 10 minutes. Keep your old one as a spare.
  4. Oct 17, 2017 at 11:29 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I did nothing and still going strong at 180k
  5. Oct 17, 2017 at 11:31 AM
    Pringles
    Pringles Active Member
    North Georgia
    2017 TRD Offroad DCSB
    I would do the service in order of what is the most expensive part to replace if it fails due to lack of maintenance. So for me, transmission, diffs and t-case would be priority. Just my opinion though.
    03f5sp and 2009Access4x4[OP] like this.
  6. Oct 17, 2017 at 11:31 AM
    taco2010trd
    Tampa, Florida
    That's a good list. I have 140k and have done all of those. The nice thing about tacomas is that they are easy to work on.
  7. Oct 17, 2017 at 11:33 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Can you elaborate on this?
    xguntherc likes this.
  8. Oct 17, 2017 at 11:46 AM
    2009Access4x4
    Shane
    Thanks for the great replies. I like the idea of doing them in order of most expensive failure. You guys think $149 for the tranny fluid change is a decent price? I don't have time or tools to do it myself right now.
  9. Oct 17, 2017 at 11:54 AM
    taco2010trd
    Tampa, Florida
  10. Oct 17, 2017 at 11:55 AM
    Pringles
    North Georgia
    Is your truck manual or automatic?
  11. Oct 17, 2017 at 11:56 AM
    Stewbuff
    Stewbuff Well-Known Member
    Andrew
    Centerville, UT
    '05 AC TRD OR Impulse Red
    Diff Breather Extension
    There is a difference between a flush and a change.
    Change: only replaces the fluid in the drain pan.
    Flush: replaces all fluid in the transmission.
    So I'm guessing that price is for a change and not a flush.
    Threads to do both services:
    DIY transmission flush
    DIY transmission fluid change
    TuRD-offroader likes this.
  12. Oct 17, 2017 at 11:57 AM
    roytown
    Sure can. I buy the silicone lubricant that's in a spray bottle. I take the hose and with the windows down I will slowly apply the lubricant into the seam where the glass rides up and down (rail? I'm unsure of the official word of it). Put the window up and down a few times and wipe away the excess (I go over the plastic trim with the excess that's in the towel, it helps "restore" the fade).
    For keys I spray into the actual locking mechanism, or the ignition put the in the key and remove it a few times and give it a few turns in each direction. Wipe away excess.
    gkomo[QUOTED] likes this.
  13. Oct 17, 2017 at 11:58 AM
    roytown
    Ehh, that's the same price my dealer quoted for it so standard maybe??
  14. Oct 17, 2017 at 12:00 PM
    2009Access4x4
    Shane
    It's an automatic
  15. Oct 17, 2017 at 12:05 PM
    2009Access4x4
    Shane
    I believe the quote was for a flush. I'm in Philly. That was the cheaper of three places and this is a dedicated tranny shop
  16. Oct 17, 2017 at 12:12 PM
    tball
    tball New Member
    Trevor
    2005 4x4 longtravel tacoma
    camburg front end dmz spring under deavers fox 2.5 coilovers in front fox 3.0 triple bypass in back Fully plated frame Ump filter intake system
    Just did my coolant flush and tranny flush over the weekend I got 153xxx miles on mine with a manual transmission took it to a trusted shop and they did everything for about $250. Also in SoCal so everything is more expensive lol
  17. Oct 17, 2017 at 12:27 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Hopefully most of the things that you mentioned have already been done. Check your owner's manual for the proper intervals...
  18. Oct 17, 2017 at 1:18 PM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    Be careful who flushes the tranny. Certain types of flush machines can damage the tranny I’ve been told. Someone here could probably elaborate... or call BS.
    I let the dealership flush mine. It was about $300. A pan drop/refill was about half that.
  19. Oct 17, 2017 at 1:33 PM
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    What are you guys using on the radiator flush? I bought a gallon from the stealership and it was 19.00 for 50/50. Seems like looking in the owners manual didn't really tell me much.
  20. Oct 17, 2017 at 1:57 PM
    roytown
    To flush it I'm going to drain the radiator and the block from all the drain ports. Close the ports up and run water from a hose through the system to get all of the old stuff in the deep parts out and then open up all the ports again to get as much water out. Then refill with the 50/50 mix, got mine from the dealer too....at a higher price :angrygirl:
