100k mi radiator drain and fill (V6 engine).
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Hiker46, Sep 22, 2022.
  1. Sep 22, 2022 at 4:22 PM
    Hiker46
    Hiker46 [OP] Well-Known Member
    Tim
    Colorado
    2023 OR 4X4 Access Cab, Auto Trans,
    OVRLND Camper.
    This was about the easiest fluid change I've done so far (and I've done all of them). I used this kit, which made the whole process easy:
    https://www.amazon.com/dp/B01I40ZQWE?ref=ppx_yo2ov_dt_b_product_details
    I drained only the radiator and not the engine block. I have an RCI skid plate but the drain valve is to the right of the plate, so I didn't have to remove it. Given the process was so easy I'll probably do it again at 125K mi. The old fluid was a dirty orange whereas the new stuff is the Toyota 50/50 pre-mixed pink stuff. Use the blue fittings in this kit. Draining and filling the radiator took about 15 minutes until the radiator was full. Then you turn on the truck and let it warm up so the thermostat opens and the fluid starts circulating through the engine and the heater core. While this is going on you can squeeze and release both the radiator's inlet and outlet hoses and you'll see lots of bubbles come up through the clear funnel. As the truck is warming up I rev'd it up to 2-3K and that helped in moving the fluid through the engine, heater core and radiator. I also turned on the heater to move fluid through the core. When you no longer see any bubbles the system should be full. I drained about 1 gallon from the radiator and 1 gallon of the new fluid was all that was required for the fill. I had enough of the new stuff to fill the reservoir. I'll drive it for a few days and check and top off, if needed.
    All in all, very easy.
  2. Sep 22, 2022 at 8:05 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Yeah I just did mine few weeks ago
  3. Sep 23, 2022 at 12:07 PM
    WinterFalco
    WinterFalco Well-Known Member
    Donald
    2018 Midnight Black SR 4x4 Double Cab
    Added aftermarket Rims and Tires, Fog Lights, Mudflaps, Entune with Nav
    Did mine the same way at 50K. Got a gallon out also. Mine was still pink, but I wanted to prevent it from coming acidic.
    mquibble and shotgunbilly420 like this.
  4. Dec 7, 2022 at 6:35 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Thank you OP for the step by step write up ! Very nice write up . :thumbsup:
  5. Dec 7, 2022 at 10:03 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    What did you do with the old fluid ?
    CG256 likes this.
  6. Dec 7, 2022 at 11:18 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Completely worthless. If you didn't drain and flush Complete system, the new fluid is contaminated with the old fluid that was left in there. Goes for the same when people do transmission that way.
    IEsurfer likes this.
  7. Dec 7, 2022 at 11:26 PM
    JTacoma4life
    JTacoma4life Well-Known Member
    2017 Tacoma TRD Sport
    Blazing Blue Pearl. Debadged. Gloss black tailgate inserts. Thinking about Katzkin Leather
    Thanks for the write up! I’m approaching 100k and will be doing this method!
  8. Dec 8, 2022 at 8:45 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    :rolleyes:
  9. Dec 8, 2022 at 10:15 AM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    The solution to pollution is dilution.
  10. Dec 8, 2022 at 10:35 AM
    23TacoSR
    23TacoSR Well-Known Member
    I would encourage you to find a retailer that accepts old coolant for recycling/proper disposal. I know AutoZone accepts it as well as NAPA. Or you might check with your county for other possible locations.
  11. Dec 8, 2022 at 10:52 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    My TOYOTA truck came with a lifetime coolant and being that the average lifetime for a male in the US is 74+, I may have a ways to go before replacement.
    That, and as my bad luck would have it, I’ve found I’ll get a leak shortly after. Usually the water pump.
    So now I just wait till some other (non-lifetime) component like a hose or radiator craps out and I plan on doing it then.
    On my last long term TOYOTA, (4R) I put some 200k miles and 13yrs of daily service and had no issues. Ran like new, so there’s that.
    Carry-on.
    I'll just be waiting...
    23TacoSR likes this.
  12. Dec 8, 2022 at 11:42 AM
    maxmk8
    my local auto zones and napa's only accept oil.
    SmoPo16 likes this.
  13. Dec 8, 2022 at 11:48 AM
    23TacoSR
    Interesting. Here in Minneapolis they accept coolant.
