100K mile mark
Discussion in '4 Cylinder' started by danteisme, Feb 21, 2013.
  1. Feb 21, 2013 at 5:12 AM
    danteisme
    danteisme [OP] Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    my 2005 2.7 4x4 is less than 1000 miles away from hitting the 100,000k mile mark. bought her with 39K on the odo. anything in particular i should think about as far as maintenance? i think i'm pretty well covered but it never hurts to have a second set of eyes look.
    i change the oil every 5K, synthetic oil.
    i change the oil the transfer case, transmission, front and rear diffs every 35Kish miles. also synthetic oil
    i changed the plugs at around 80 or 85K due to a missfire. changed with factory plugs.
    i lube the u-joints every oil change, 5K
    i replaced the serpentine belt at around 90K miles.
    i believe thats it as far as maintenance goes. maybe someone can chime in with another idea and it will jog my memory whether or not i already do it.
  2. Feb 21, 2013 at 9:23 AM
    SocoandLime
    SocoandLime Active Member
    Just check your manufacturer manual.
    Also don't forget to take a picture!
  3. Feb 22, 2013 at 11:27 AM
    alwaysfaded
    alwaysfaded Well-Known Member
    Adam
    So. Cal.
    08 Black taco, 5 spd.
    blacked out tint, k&n drop in, removed secondary filter, kenwood 7" touchscreen, 12" memphis audio sub, 1000 watt amp, Alpine type R conponets
    I'm almost at 100,000 miles as well. I am going to change the plugs soon. I got a question though, I have the 5 speed. Am I supposed to change the oil in this?
  4. Feb 22, 2013 at 11:28 AM
    danteisme
    South Western PA
    i would say it is a good idea. i'm sure it states in the manual the frequency it needs to be changed, i don't have mine with me right now but i'm sure its in there.
  5. Feb 22, 2013 at 6:58 PM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    dont forget the coolant.
    I tried to find a interval for the 5-lug 5 speed model tranny fluid and came up empty. I am at 60K and mine is paid for, so time to do some maintainance.
  6. Feb 22, 2013 at 7:01 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Shocks?
  7. Feb 23, 2013 at 3:01 AM
    alwaysfaded
    Adam
    So. Cal.
    I know I cant find anything about the tranny either.. I would imagine it would be good idea at 100k though
  8. Feb 23, 2013 at 5:11 AM
    RMay
    RMay New Member
    Bob
    Louisiana
    13 PreRunner L4
    You might consider changing/flushing the fluid in the brake system. I was surprised how black the fluid in the middle of the lines can get after that many miles. I did it in my Honda Accord with 150,000 miles. Could be one of those just makes you feel better things! Just a thought.
  9. Feb 24, 2013 at 4:43 PM
    danstruck
    danstruck Member
    dan
    ocoee, florida
    06 tacoma 5spd 4wd 2.7, ome 3inch lift
    hard bed cover, step tubes
    Am at 97k in mine , ahve had since new. All i have done is plugs at 80k front breaks at arround 80k also and just did rear, changed all the oils in trans t-case and diff back arround 35k, switched to high quality synthetic. If your not under water much you really dont have to worry about changing the oil in a manual transmission as long as its not leaking.
