100k mile tramsmission service
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kbuild, Jun 21, 2018.
  1. Jun 22, 2018 at 1:25 PM
    NCtaco13
    NCtaco13 Well-Known Member
    North Carolina
    2013 Gray DCSB 4x4 V6
    I flushed my transmission the same way as described in this thread and it was very simple I think I went through 3 gallons of full synthetic atf for it. I also dropped the pan and threw in a new filter all is very easy. The hardest part for me was filling the transmission back up because the full plug is in a terrible spot but I also didn't have a pump or spray bottle of any kind to use. I also had a tranny cooler on my truck which made the flush super easy
    taco2010trd[QUOTED] likes this.
  2. Jun 22, 2018 at 5:46 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It is heat that kills the fluid, not miles. My dad worked in sales and drove his personal vehicles 40,000 miles a year on average. He put 200,000+ miles on everything he ever owned and never once paid for a transmission service or repair. And this was in the 1960's through the 1980's. I'd say that most transmissions today are good for at least 200,000 without ever changing the fluid, even if the owners manual says to. My manual says don't change unless used under extreme conditions. I have mine checked once a year and after 11 years and 190,000 miles my fluid is just fine. I figure I'm good for another 200,000.
    If you can keep the ATF pretty close to, or under 200* the rest of the truck will fall apart before the transmission fluid fails. The hotter it gets, and the more time you operate at high temps means the fluid is compromised. If you're in the 210-220* range very often then changing every 30K-50K is probably a good idea. If you ever reach 250* the ATF is toast and should be replaced ASAP even if you just replaced it 2 weeks ago.
    If you're over about 150K I wouldn't touch the fluid. If you've done any damage replacing the fluid at this point won't fix it. The transmission is doomed to fail. But keeping the old fluid in there may well buy you another 20K-50K before it goes. Changing the fluid at this point will very well speed up the process. This is why many shops don't want your money. It isn't worth the hassle and bad mouthing customers will give them when they claim it worked fine when they brought in the truck and the transmission failed a week later.
  3. Jun 19, 2020 at 8:59 AM
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    in order to get the most possible life out of the automatic in my 2015 I have done everything suggested here.
    1)added an additional ATF cooler with a 180F thermostat... Keep atf under 180 but not over cool. hotest temp I ever saw was 174F (but I have never towed so far)
    2)Have an inline magnefine filter (changed every 30K).. I am not worried about the atf wearing out as long as its kept cool but want to get rid of the accumulated debris from normal wear.. having seen the superfine ferrous particles it removes I am glad its picking them up rather than all the solenoid operated valves .
  4. Jun 20, 2020 at 2:23 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Lots of opinions on this.
    The dealer will do a full flush for you no questions as its a fluid that wears/deteriorates and replacing sure helped mine at 100k and it shifts firmer and the torque converter lockup is better in 5th. Its the sealed world unit that Toyota uses. If you tow anything do it. I have the factory tow package. Believe what you want.
  5. Jun 20, 2020 at 5:11 AM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    This is what I did at 87,000. I was initially going to just do the flush, but after conferring with @gearcruncher he recommended first dropping the pan, looking at the screen filter and cleaning and inspecting the magnets. I flushed about 16 quarts of MaxLife to ensure I got all the WS out, might be over kill, but it’s only $17 a gallon. I have about 3k miles on since the pan drop and flush and I’m very happy with the results.
  6. Jun 20, 2020 at 9:31 AM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
