100k miles, Syn or Dino oil?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Parkvisitor, Sep 6, 2019.
  1. Sep 8, 2019 at 6:25 AM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Sorry, I sold my parts stores about 10 years ago and my memory has faded for most specific part #s. I did handle Dorman products though.
  2. Sep 8, 2019 at 6:31 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    semi synthetic
  3. Sep 8, 2019 at 6:31 AM
    Kevin Jones
    Kevin
    Va
    I'm a Pennzoil fan as well, even though I use Mobil1 in my '18 TRD Sport and C7 Corvette.
    I've used regular 10w-30 Pennzoil in my '96 Tacoma since it's first oil change 413,000 miles ago. No leaks an it will only burn about 1/4 quart over a 5000 mile oil change period.
  4. Sep 8, 2019 at 7:04 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I buy whatever 5w30 is on sale and change my oil every 5k. These trucks aren't hard on oil so anything that meets OEM spec is fine as long as you actually change it when you're supposed to.
    outlawtacoma and JPinFL like this.
  5. Sep 8, 2019 at 8:11 AM
    JPinFL
    JPinFL Well-Known Member
    '01 Tacoma Xtra Cab 4x4
    I used Castrol High Mileage conventional after it hit 150k miles. Switched to Pennzoil High Mileage conventional the last few oil changes because it was cheaper. No problems with either of the two. I am at over 325k miles.
  6. Sep 8, 2019 at 3:46 PM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I just put 5/30 Mobil 1 in mine because it was on sale. Normally run 10/30 Pennzoil. Now I can smell it occasionally burning oil and the valve cover gaskets are weeping. I plan on going back to conventional.
    CS_AR likes this.
  7. Sep 8, 2019 at 3:54 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There is no downside to using synthetic at any time.
  8. Sep 8, 2019 at 4:19 PM
    Parkvisitor
    Parkvisitor [OP] Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    I used a small ignition wrench to tighten the low side valve cover bolts, stopped a small leak. Those bolts come loose over time.
    Rachelsdaddy[QUOTED] likes this.
  9. Sep 8, 2019 at 5:45 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Doesn't matter. Just change it regularly.
    JPinFL and Rachelsdaddy like this.
  10. Sep 8, 2019 at 6:20 PM
    JPinFL
    When I was 16, my uncle told me the same thing when I asked him what oil I should use?
  11. Sep 8, 2019 at 7:15 PM
    jbrandt
    Justin
    But the guy on the TV tube told me that the $16 a qt purple stuff is way better! Adds like 12 hp, too!
    JPinFL[QUOTED] likes this.
  12. Sep 9, 2019 at 4:26 AM
    Rachelsdaddy
    Southern NH
    And if you add Slick50 (some will remember) you can dump sand in the valve train while hosing it down with a fire truck. Funny how the commercial is only 30 seconds.....
    JPinFL likes this.
