100k repairs and sparkplug/wire help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, May 31, 2011.
  1. May 31, 2011 at 10:44 AM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    so i am a little past 100k and i was wondering what you fellas think should be done? i have a valve cover leak soo on my list...
    1. Vavle cover gasket
    2. Water pump (leaking)
    3. oil and fuilds
    4. grease drive shaft
    5. plugs (see below)
    6. Plug wires (NGK sound good?)
    7. Clutch is going so what would you guys recomend? marlin? I want something stronger than stock as i burnt that B**** out fast.
    8. Last thing what about new rotor and distributor ??? figure i should replace them while i am at it.
    any thing i forgot???
    Also for the plugs i heard about these from a friend at work and they seem pretty sweet. what do you guys think? and which ones would fit my 3rzfe??
    http://pulstarplug.biz/Main/PULSTAR-page.asp?P=21
    EDIT:
  2. May 31, 2011 at 10:46 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Put new diff fluid.
    edit: over read you put "oil and fluids" myb
  3. May 31, 2011 at 12:13 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Just use the stock Denso plugs. Unless your engine is significantly modified, the Densos are cheaper and better than anything else. Most aftermarket plugs are just BS hype. You pay extra to support the creative-writing techno-babble snake oil, and then odds are even that they will either be no better than stock or start causing performance issues.
    To check all required maint. items for your specific truck, register here and enter your VIN:
    http://smg.toyotapartsandservice.com/index.php
    How did you "burn out the clutch fast?" The stock clutches will last 200k to 300k miles if driven properly.
