100K, safe to switch to Synthetic?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sawx75, May 23, 2017.
  1. May 23, 2017 at 3:26 PM
    sawx75
    sawx75 [OP] Active Member
    Massachusetts
    2010 Red TRD Off Road
    Recently picked up a 2010 and did my first oil change with what the shop recommended. I have run synthetic in all of my previous vehicles with great results. Is it safe to switch to synthetic at this point? I do not mind the added $$$ if it will help, I just want to know if there are any negative effects of changing from regular to synthetic at this point. (the previous owner did not use any synthetic)
  2. May 23, 2017 at 3:29 PM
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    If you have any small oil leaks, they will become big ones if you go to a lower viscosity oil. If your rig has only had conventional, why switch? Just change it every 3-5K miles.
  3. May 23, 2017 at 3:30 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    It's safe to change to synthetic
    Shark18 and Plain Jane Taco like this.
  4. May 23, 2017 at 3:32 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    you can change back and forth all you want!
  5. May 23, 2017 at 3:32 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    You can change. Just use he same weight oil.
    My truck had conventional oil till 40k, then I went with synthetic. No issues.
    Shark18 likes this.
  6. May 23, 2017 at 3:50 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    It'll blow your mind that there is a type of oil called 'semi synthetic' that is a mix of conventional and synthetic, and is used in millions of cars everywhere.
    Yeah you're fine.
  7. May 23, 2017 at 3:51 PM
    wheeliest
    Json
    TMPE AZ
    I run rotella T6 in everything
  8. May 23, 2017 at 3:53 PM
    outlawtacoma
    W. TN
    2018 T4RTRDOR
    My brother runs that in his old 4runner. Thing purrs like a kitten.
  9. May 23, 2017 at 3:54 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'd be more worried what the diff oil looks like but I say live on the edge and go for it!
  10. May 23, 2017 at 4:00 PM
    Moogle
    Moogle Dyslexic Stanist
    Glen
    Alameda, CA
    07 Silver TRD Sport DCSB 4x4 6-speed
    Blood of virgins
    I'm still on my first fill of synthetic (Mobil 1 High Mileage) after switching at 120,000 miles. I had no leaks before and no leaks now. Had a sample tested after 5000 and report said it would be good for another 2000, but I'll probably change it earlier since it's my first change on synthetic.
    Plain Jane Taco likes this.
  11. May 23, 2017 at 4:03 PM
    wheeliest
    Json
    TMPE AZ
    Yeah fk scientist and there "suggestive intelligence" on what its good for.
    libagui and SilverBullet19 like this.
  12. May 23, 2017 at 4:05 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    Switching back and forth between synthetic and conventional will not cause problems ever, and anyone who says it will doesn't know what they're talking about. The metal in your engine doesn't care if it's synthetic, semi-syn, or conventional. As long as it's clean oil and the proper weight you're good.
  13. May 23, 2017 at 6:44 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    It really doesn't matter, just select a grade that matches your climate (10W-30 for most of the US in the Summer) and number of miles on the vehicle (10W-40 or 20W-50) as the miles rack up (150+k). The various "max" or extended life oils are good for higher mileage vehicles as they contain seal rejuvenating and other additives that can be of some benefit in older high mileage engines.
    Conventional or synthetic doesn't really matter as long as you adjust your change intervals accordingly, and do not race or otherwise abuse the engine (High loads, high temperature operation). 2500 to 3500 miles for dino juice, 4500 to 5000 for synthetic.
    Breakdown of the oil's basic lubricating qualities is really secondary to the build up of combustion by-products that acidify and thin the oil, additive breakdown, oxidation of the oil itself, etc. are the main factors affecting a motor oil's useful life. Synthetic oil withstands some of these condition better than dino, but in normal use for most driver's and service dutys not enough to warrant the added cost (IMHO).
    Use a good quality oil, of a grade proper for your conditions, and keep it clean by changing it each 3000 to 3500 miles--and drive the car for 14 years and 240k miles like my wife's '03 HIghlander--it's been running on 20W-50 MaxLife (Florida) for the last 125k . Her '89 Celica had 445k when we traded it in--it ran 20W-50 for 320k+ miles...
    My grandfather told me many years ago that "Oil is cheaper than engines", he was right then and it still holds.
    Nedrolls and sawx75[OP] like this.
  14. May 23, 2017 at 7:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you must be 50+ years old...... synthetics of the 70's n 80's caused this to happen..... not synthetics of today.
    OP you have no issue switching to synthetic. Run the recommended weight (Xw-30) in your v6 and call it good.
    I personally prefer 0w-30 mobil 1 regardless of climate, as even at 100* ambients, a 0w-30 oil is still thicker than its operating 30 weight at operating temperatures, so 0w will protect your motor better while its warming up. And unless you live in a VERY cold climate (single digits n below) there is no reason to go with a thinner oil (ie 0w-20) as your motor once warmed up will be the same temp regardless of ambient temp (you can thank your cooling system for that)
  15. May 23, 2017 at 7:13 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Eh, even synthetic oil is cheap relative to an engine. I'd rather play the safe side than run it to it's last mile of goodness every change. But I wouldn't get an analysis in the first place unless I thought something was wrong. For that price you may as well just change the oil.
  16. May 23, 2017 at 7:15 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    This is the first 'Can I switch to synthetic oil thread?' ... ever!
    I wish that I had thought of that!
    Ruggybuggy and cliffyk like this.
  17. May 23, 2017 at 7:40 PM
    orezona
    satan's skillet
    WARRANTY VOIDED
    Yup, called me out.
    I'll stick with my plan and you stick with yours and at the end of the day, I'll buy a round and you can buy a round.
    libagui and cliffyk like this.
  18. May 23, 2017 at 7:41 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    Here in Florida I would not put 0W or 5W in anything, except maybe an oil can for the ways on my lathe. We live 1-1/4 miles from the ocean and the coldest it has been here for 10 years was 38° F--that was outdoors, it was 50 in the garage--and it went up to 54 outdoor by noon. We had to endure these "freezing temperatures" for three days before things got back to normal. Today was kind of cool, it started out at 70 and was 94 in mid-afternoon. In this climate there is no need for 0W-nn or 5W-nn grade motor oil, in fact for 90+% of the year it cannot and does not provide optimal startup protection.
    The thin oils (motor and transmission) recommended by automakers are so as to pump up their CAFE numbers, and save them money on CAFE fines; which more than doubled last August. Engine life is a far distant consideration, all they care about is that it last 60 months/60k miles. Toyota makes a pretty good engine, you could probably fill the crankcase with peanut or sesame oil, change it every 3000 miles, and have it last that long...
    orezona likes this.
  19. May 23, 2017 at 7:44 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    Conventional oil is so underrated. It's the shit, man.
  20. May 23, 2017 at 7:47 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    DO NOT EVER PUT 20W-50 IN YOUR ENGINE EVER! NO MATTER HOW MANY MILES IT HAS!
    This is not a piece of farm equipment. The 4.0 has a variable valve timing system that is very dependant on a good clean supply of THE CORRECT WEIGHT OIL! it says it right on the cap.. it's not a suggestion, it is what the engineers that designed the engine decided to use.. any deviation from what they decided to use in terms of weight, viscosity is a poor idea..
    mojojojo78 and libagui like this.
