100k service?
Discussion in 'Arizona' started by dira1987, Oct 29, 2012.
  1. Oct 29, 2012 at 1:30 PM
    dira1987
    dira1987 [OP] Well-Known Member
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Just turned over 100k! I'm thinking about the service I should do and I'm trying to do out all myself. Already did the brake pads, rotate the tires, and an oil change. What else should I do? is there something I should take a look at since the car has spent it's whole life in az? If anyone has any advice or would like to walk me through some steps let me know!
  2. Oct 29, 2012 at 2:30 PM
    Seabass
    Seabass Chrome won't get you home
    Adam
    AZ
    '06 Sport 4x4
    You don't really care, do you.
    You should flush all fluids now (tranny, brake, power steering, coolant) and also change your diff fluid(s).
  3. Nov 1, 2012 at 3:24 PM
    dira1987
    David
    Chandler AZ
    2003 LT Prerunner
    Metal.
    Thanks! I figured i would have to do all of that but this just confirms it. I think ill try to do a little bit every weekend.
    Open invitation this sunday if anyone wants to join me and do some brake fluid/power steering fluid/coolant ill be getting it done. Im over in chandler if anyone wants to stop by or do some work on their truck. I dont have a ton of tools, but i think ill have the minimum to get those jobs done. PM me if youre interested.
  4. Nov 1, 2012 at 6:01 PM
    Enino12
    Enino12 Well-Known Member
    Eric
    Phoenix
    06 PreRunner Dub Cab
    Two 10" Rockford Fosgate P2 Subs, R/T 10" Dual Ported Box Behind Back Seat, Powered by Rockford Fosgate Punch 600.2 T Amp, 3" Rough Country Suspension Lift, Tacoma Running Boards, N-fab Light Bar, 4 KC HiLites, More to come soon
    I just hit a 100K in my truck as well. I just changed out my oil and spark plugs and i should probably get around to changing out the fluids as well. I've only changed out my oil and spark plugs myself but i'm down to help in whatever way i can and learn some new things about my truck. I've also got a ton of tools I can bring :) haha
