103k miles... time for a Tune-Up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Axian, Jul 12, 2017.
  1. Jul 13, 2017 at 9:42 AM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    This I have not done, i'm going to look into replacing it this weekend.
  2. Jul 13, 2017 at 9:51 AM
    captn.fat.beard
    captn.fat.beard Well-Known Member
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    i have recently broken the 100k mark. I'm at 100,388 to be exact. I had the 100k service done at the dealer at 92,700. They didn't change the belt because allegedly, it "looked fine", and they also claim that they don't do the diff oil either. With that being said. Don't take it to a dealer. The only reason I did is because I lived in an apartment complex at the time, and per the lease, you weren't allowed to work on your truck. Now I'm back in Philly, and I have zero issue doing it on the street, or going up to my parents house in central jersey. There are also a plethora of members that are willing to pitch in, live and in person, hence why I joined the forum. I'll look here for advice, before I trust the word of any dealer or shop.
    If youre unsure of the maintenance history, do it all. This way you know for certain its done, and up to date.
    91859706 and NAAC3TACO like this.
  3. Jul 13, 2017 at 1:59 PM
    crdnlplt
    crdnlplt Well-Known Member
    SE PA
    17 dcsb trd or
    It's fine just to clean with some brake cleaner. They're nice metal ones, not the cheapo plastic pieces.
  4. Jul 13, 2017 at 2:11 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Grease your driveshaft zerks, check the air filter, plugs, oil (engine, front/rear diff), alignment, give it a good bath.
  5. Jul 13, 2017 at 2:14 PM
    Larueminati
    Western MA.
    I just picked a new one up at the dealer for $6.50
  6. Jul 13, 2017 at 2:14 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    o_O
    o_O
    OP, I'd change the fluids (motor oil, front and rear diff and transfer case, brake fluid, coolant flush, transmission drain/fill), grease the driveline, new air and cabin filters, replace spark plugs, replace serpentine belt, replace wiper blades, and check water level in battery if it's not a sealed unit.
    Axian[OP] likes this.
  7. Jul 13, 2017 at 5:47 PM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
    I wouldn't. Do some more research on this specific to our trucks. If it ain't broke dont fix it.
  8. Jul 13, 2017 at 5:53 PM
    Yota64
    Yota64 Professional Threadjacker
    100K plugs my butt. Mine were gapped 0.100 when I did my tuneup. That's so out of spec it isn't funny. Ran great though. Yes, do your tune up. It's like taking your truck on a date.
  9. Jul 13, 2017 at 6:39 PM
    stickyTaco
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Agreed that a flush is not a good idea but a drain/refill is in my opinion.
  10. Jul 13, 2017 at 6:59 PM
    crdnlplt
    SE PA
    17 dcsb trd or
    Good deal, thought they would have been more.
  11. Jul 13, 2017 at 8:44 PM
    Kev O
    Kev O Well-Known Member
    Oregon
    15' DCSB TRD OR
    255/85 Cooper S/T MAXX. Leer 100R. 885's/5100. Dakars & B110's.
    Don't forget power steering flush too.
  12. Jul 14, 2017 at 10:58 AM
    uwu
    uwu Well-Known Member
    Just file your points and change your glow plugs... all is well again!
  13. Jul 14, 2017 at 12:01 PM
    Teuton
    Teuton Well-Known Member
    2011 Reg Cab 4x4, 2021 TRD sport, 2024 TRD Sport
    oil change, differential/transfer case oil change, transmission fluid drain and fill, spark plugs (clean throttle body while at it), coolant flush, change motor and cabin air filter, and grease driveshaft zerks.
    Thats what I plan on doing when I hit 100k on my 2.7. Currently at 85k
  14. Jul 14, 2017 at 2:32 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    But that's unsprung mass, it won't make a difference
    LOL
  15. Jul 14, 2017 at 7:59 PM
    #35
    SJC3081
    SJC3081 Well-Known Member
    Wappinger NY
    2011 DCLB 4x4
    also check and if needed replace the blinker fuild.
  16. Jul 15, 2017 at 8:16 AM
    #36
    finslayer83
    finslayer83 Well-Known Member
    TN
    TRDP 4runner / 01 Taco
    A lot
    Only buy OEM for this. I've found if you call the local dealership and speak with the parts manager they will usually give you some for free.
  17. Jul 15, 2017 at 8:32 AM
    #37
    Greg617
    Greg617 Well-Known Member
    Greg
    New England
    2010 5-speed 4x4
    Dents and scratches... Fox 2.5 Factory
    I was wondering the same thing when my truck reached 100k, and ended up doing a few things between 100k and 105k. Made a big difference overall.
    - Replaced the fluid in both differentials, transfer case, and transmission (Royal Purple in transmission)
    - New spark plugs (NKG IX Iridium)
    - New duralast gold battery
    - Replaced the upstream and downstream oxygen sensors (upstream failed and HAD to be replaced)
    - Painted my undercarriage with magnet paint chassis saver. Sanded off minor rust before painting.
    - Rotated my tires
    I have always done my oil changes every 5000k with mobile 1. Grease the u joints on the driveshaft every oil change as well.
    Nice profile pic :crapstorm:
    Axian[QUOTED][OP] likes this.
