1056 miles...BOOM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wawuzit, Feb 20, 2019.
  1. Feb 20, 2019 at 1:58 PM
    wawuzit
    wawuzit [OP] Well-Known Member
    steve
    Clinton, Tennessee
    2019 gray 4dr Tacoma TRD
    none
    HIGH TRANSMISSION FLUID TEMPERATUE WARNING
    check engine light
    3 safety feature icons light up
    traction control light
    Message.. Stop engine see dealer
    This all happened while sitting at a major intersection in the pouring down rain.
    Engine would restart but only idle. Transmission would go in drive but if you gave it ANY gas it would die.
    How do you get a high temp. trans. warning if no fluid leak, not pulling a load , 50 degrees , and stopped at a red light? Dealer gave me a new Tacoma to drive and paid the tow bill.
    Any guesses or comments?
  2. Feb 20, 2019 at 2:02 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Sport so guessing yes.
  3. Feb 20, 2019 at 2:06 PM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Tow to dealer.
    TnTuna and shakerhood like this.
  4. Feb 20, 2019 at 2:09 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Maybe low on trans fluid
  5. Feb 20, 2019 at 2:10 PM
    Vonhetzer
    Vonhetzer Well-Known Member
    IN
    19 Taco
    I'm sure it's an isolated incident but it does make me pause for a sec. Just rolled over 1k and coming from a no issue 207k makes me wanna go hmmmmm...
  6. Feb 20, 2019 at 2:19 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    YES no leaks at all.
  7. Feb 20, 2019 at 2:21 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    How would it get low? No leaks . never towed anything.
  8. Feb 20, 2019 at 2:21 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Low from the factory. Common problem on here with 3rd gens and even some 2nd gens with the auto
    Rujack, Mr-Paul, Stryker420 and 3 others like this.
  9. Feb 20, 2019 at 2:22 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    It's up on their rack with several people looking into it.
  10. Feb 20, 2019 at 2:23 PM
    Grossomotto
    2017 4WDV6LB6MT
    Sometimes they’re low from the factory. Tell the dealer to properly check the level, Trans has to be at a certain temp.
  11. Feb 20, 2019 at 2:23 PM
    tcjacado
    tcjacado Well-Known Member
    Good luck.
    shakerhood and StayinStock like this.
  12. Feb 20, 2019 at 2:25 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    If it was low from the factory how did I drive it 1056 miles without a problem? Confused I'll post a copy of the service done to the truck.
    PvilleJohn likes this.
  13. Feb 20, 2019 at 2:26 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Pretty sure those are all the symptoms of a bad crank position sensor.
  14. Feb 20, 2019 at 2:26 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
  15. Feb 20, 2019 at 2:27 PM
    Grossomotto
    2017 4WDV6LB6MT
    It’ll drive just may show issues later.
    See what they say. They’ll pull the codes.
  16. Feb 20, 2019 at 2:27 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    What made al the other icons and lights come on, they were not related to the transmission. Strange.
  17. Feb 20, 2019 at 2:29 PM
    Grossomotto
    2017 4WDV6LB6MT
    It’s most likely what others have said, probably a sensor. Low fluid level won’t make the warning lights come on, was just letting you know to have them check the level while they’re at it
  18. Feb 20, 2019 at 2:32 PM
    charles.headlee
    charles.headlee Well-Known Member
    East TN
    Curious, what dealer (I had a bad experience at the one I'm expecting to hear)?
    What intersection?
  19. Feb 20, 2019 at 2:33 PM
    DansSr5
    DansSr5 Well-Known Member
    2016 Sr5 double cab silver 4x4
    P265/75/16 Destination AT stock wheels 12v socket bed pocket install diy Truck bed beer bottle opener No drill hidden/uv5r ham radio installed GoPro hero 5 session Center console organizer and top tray Front air dam delete Sidestep delete Add factory mudguards Recovery/equipment: Everything fits behind or under the seat Tool roll up bag Battery terminal cleaner Electrical grease for terminals Digital multimeter Alternator tester 4 gauge jumper cables Breaker bar with 19&21mm sockets Viair compressor Tire deflator Tire repair kit Tarp Hitch with d-ring Standard hitch 1 1/8 to 1 1/2 open ended hitch wrench Rope Ratcheting tie downs Tire gauge Cellphone charger wall/socket adaptors Gloves Recovery strap Crowbar Mighty might fishing pole Small tackle box First aid kit Michelin road atlas (4) 1 liter water bottles in rear doors 1 empty grey plastic ammo can (not sure what to put in it yet).
    Probably Smitty's old Truck that he rolled back the miles before he traded it in.
    BRFab, Spare Parts, Bridge4 and 11 others like this.
  20. Feb 20, 2019 at 2:35 PM
    wawuzit
    steve
    Clinton, Tennessee
    none
    The largest one in Anderson Co. 21 lanes of traffic! Rusty Wallace Chevy. 1pm downpour
