105K scheduled maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NIDtacoman, Nov 14, 2017.
  1. Nov 14, 2017 at 11:06 AM
    NIDtacoman
    NIDtacoman [OP] New Member
    2011 Tacoma
    Received a postcard from dealer today that tells me I need 105K scheduled maintenance. What is needed at 105K?
    I have previously done just about everything myself (plugs, oil & filters and fluids) except trans.
    Should I or should I not have the transmission fluid flushed since I have never done it before?
    thanks
  2. Nov 14, 2017 at 11:13 AM
    Tonka08
    Tonka08 Well-Known Member
    Eugene
    Vail
    08 Tacoma 4x4 offroad DC 6sp manual 5' bed
    TRD Supercharger, aFe Headers & Y-Pipe (48-46001-YC), aFe Magnum Force State II Si Pro Dry S Air Intake, aFe POWER 49-46001-1P MACH Force-Xp 3" 409 Stainless Steel Cat-Back Exhaust System. Firestone 2407 airbags. Toy tech 3.5" Lift w/add a leaf & coil-overs, Helu 17" wheels on GY Wrangler DuraTracs. Grill guard w/Westin Fog lamps, Modified Skid plate, Bug Deflector, Window Vents, 15% tint, Fold-a-cover (Tonneau) Tub Steps, Adjustable Bed Divider, Weather Techs, Custom Seat Covers, Auto Dimming Mirror & Locking Tailgate. KTV512 Stereo W/Nav Sirius & BT, Kenwood Speakers & JL Audio Stealbox Dual 10" Subs, Powered by KAC7205 Amp.
    I'd flush it but thats me probably over doing it. I did mine at 95k when I did oil, front & rear diffs. You are already down there so why not its not that difficult. I think I did my diffs and manual tranny at 50k as well. Good Luck!
  3. Nov 14, 2017 at 11:57 AM
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    I found the transmission flush to be quite easy. Did you do a power steering fluid flush? That is easy also. What about your serpentine belt? Should probably replace it as well.
  4. Nov 15, 2017 at 4:28 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I would also change air, cabin, fuel filter if you haven't done it. engine coolant.......
  5. Nov 15, 2017 at 6:58 AM
    Pigpen
    Pigpen A dirty little man
    Northwest Montana
    Access cab toolbox/ dog bed with seats and headrests deleted, waterproof TRD seat covers, yellow wire mod, diff breather relocated to tail light, engine block heater, Leer topper with Yakima tracks and rack, Yakima rack on cab, Ride Rite with Daystar cradles, CBI hidden front hitch, wired for winch front and rear Warn quick connect, Warn x8000i on external carrier, sway bar delete, trailer plug relocated to bumper, Pelfreybilt IFS and Mid skids, ECGS front diff bushing, ARB CKMA12 compressor, 255/85/16 Toyo M55 load E tires on stock steel rims, Up2NoGood heated mirror kit, Husky X-act Contour front floor liners, Northstar AGM 27F battery, Pelfreybilt bolt on sliders with kickout and top plates, TRD Pro headlights, Depo smoked tail lights, Energy suspension body mount bushing kit, Cobra 75WXST cb with rear mounted Wilson 3' antenna on Shmellmopwho mount, OME Dakar leaf packs with AAL, Billstein B110 rear shocks, 5100s with 885 coils and 1/4" spacers, SPC LR UCAs, 2wd low range mod
    Manual trans or auto?
  6. Nov 15, 2017 at 9:11 AM
    PackCon
    PackCon Well-Known Member
    Connor
    Super White 2013 TRD Sport DCLB - 2002 Ford F250 SD
    I flush my transmissions every 100k.
    I would not do this at a dealer. Go to an independent shop.
  7. Nov 15, 2017 at 9:13 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    fuel filter? how you get to that? or is there one outside tank?
  8. Nov 15, 2017 at 10:08 AM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Check the maintenance manual. What is required depends on the conditions you drive the vehicle in.
