108mm hub with a 106mm wheel bore?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Eduskator, Aug 14, 2014.
  1. Aug 14, 2014 at 10:35 AM
    Eduskator
    Eduskator [OP] Well-Known Member
    La Belle Province
    '14 Tacoma
    Hi.
    I am planning on buying those 2'' wheel spacers
    http://www.ebay.com/itm/4pc-TOYOTA-TACOMA-6-Lug-Wheel-Adapter-Spacers-2-00-Inch-Free-Ship-/371110140890?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ATacoma&vxp=mtr&hash=item5667e35bda
    But I'm aware that my OEM wheels are 106mm while the spacers have a 108mm hub.
    I found these : (108mm to 106mm rings) but I think they are inverted from what I need. (They are for 108mm wheels to 106mm hub and I need 106mm wheels to 108mm hub)
    http://www.ebay.com/itm/Hub-Centric...Parts_Accessories&hash=item3a902468f0&vxp=mtr
    Do you think these will fit if I invert them? I don't even know if that's possible.
    I know I can't install a 106mm wheel bore on a 108mm hub size because wheels won't be centered but it's the only choice I have if I want to go with 2''.
    Also, I plan on buying aftermarket rims so I don't want to buy 106mm spacers.
    I searched a bit but found nothing useful.
    Thank you :)
  2. Aug 14, 2014 at 2:53 PM
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    I think your own confusion has now confused me. I'll try and help though. Factory toyota hubs are 106mm. Factory Tacoma wheels are also 106mm center bore. If you were to get spacers, ensure they are 106 to 106. You would need those hub rings if you wanted to have the wheels hub centric and possibly prevent vibrations. For example, my wheels have a center bore of 108mm, therefore my hub rings go from 108 to 106 to fit my factory hubs. Another option is to find or order wheel spacers that go from 106 to 108 to fit your new wheels center bore. BORA can make you any thickness to any hub diameter. I hope that helps.
    Nate
  3. Aug 14, 2014 at 3:05 PM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    what you posted is totally confusing...the spacers you linked are for a Toyota, 106.1 bore and fit on the Toyota hubs perfectly...the wheels you have are 106.1 bore, you do not need any hub rings...how did you come to the conclusion you needed 108 to 106 hub rings?
    did I say your post is confusing?..BTW, there is no way a 106 wheel will fit a 108 hub, but, a 108 wheel will fit a 106 hub, and a 108 to 106 hub ring is then needed to make it hubcentric...
  4. Aug 14, 2014 at 3:43 PM
    Eduskator
    La Belle Province
    '14 Tacoma
    Yeah sorry for that... Did it at work in a hurry.
    The ebay link I wanted to send was a 2'' thick 108mm wheel spacer kit and I wanted to know if my 106mm wheels would fitt. (I updated it in my OP)
    I asked that because I don't find any 106mm 2'' spacer kit and most aftermarket wheels are 108mm...
    After thinking about it, I'll stick with the 1.5'' HubCentric made for the truck I have and probably buy aftermarket 108mm wheels with hub rings adapted to 106mm... I don't want any vibration problems or unusual wear on a brand new Tacoma...
  5. Aug 14, 2014 at 4:04 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
  6. Aug 14, 2014 at 4:08 PM
    Nate87
    Nate
    CONUS
    2013 AC TRD OR
    If your goal is to run a 2" spacer with factory rims then a 106 to 106 is what you need. I'm sure you can search and find what you need somewhere online. If not, contact the guys at motorsport tech who also make the BORA spacers(www.motorsport-tech.com). And they can make the spacers for you. If down the line you get wheels with a center bore of 108 then hub rings would be advised but not required. They sell 108 to 106 rings on Amazon for about $12.
    Nate
  7. Aug 14, 2014 at 7:03 PM
    Eduskator
    La Belle Province
    '14 Tacoma
    Wow! thank you for this. I'll take a look at the BORA ones!
    If not, I'll take the 1.5'' 106mm and buy some rings if I buy aftermarket 108mm rims.
    Thanks again.
  8. Aug 14, 2014 at 7:26 PM
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    If your gonna buy aftermarket wheels then you wont need wheel spacers at all!
    Choose an aftermarket wheel with the correct offset to get the correct stance you want. This way you erase the need for wheel spacers.
  9. Aug 15, 2014 at 4:01 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    ^^^^^^yup, what he said, it will save you some hard earned^^^^^^
    The money saved can be out towards the wheel purchase....The Bora's will cost around $250 shipped in the 1.50" range...you would be better off putting that towards your new rims with the offset you want...more solid setup in the long run...
  10. Aug 15, 2014 at 6:13 AM
    Eduskator
    La Belle Province
    '14 Tacoma
    Yes. I'll stick with 1.5'' on stock wheel for now and look for aftermarket after next winter.
    If not, I'll simply put bigger tires on OEM wheels and paint them... :)
