10k mile service update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rosst, Apr 9, 2017.
  1. Apr 9, 2017 at 5:33 AM
    rosst
    rosst [OP] Well-Known Member
    Nine month update on my 2016 dbcb offroad. Nice truck, rides and handles well and has been delivering decent gas mileage. But not all has been great. My transfer case exploded at 5k miles. Internal damage, locking it in low range. The tow and repair was fully covered and quickly resolved by Toyota with a new transfer case. Even after a transmission re-flash, I find the transmission shifting funky. I'm sort of getting used to it, but shift flare in the morning always bothers me. Hopefully another update will be coming. Another odd issue is the read wheel arch trim is discoloring at the lower leading front end. Almost looks like sand blasting is turning it light in color. I'm asking Toyota to replace these during my service visit, we'll see if they will do it.
    The black paint finish isn't great, real easy to get light scratching. I really can't take it through an automated "soft touch" car wash or I spend a couple hours after with some buffing work.
    Spare Parts and Tcoma16 like this.
  2. Apr 9, 2017 at 5:39 AM
    rosst
    Forgot to add Entune voice control is almost useless. I got sick of yelling at it and now just push buttons to operate it. I also tow a 2500 lb boat and it tows it ok, but could use more power. I probably should have gone the Tundra route.
    Spare Parts and Wheresmytaco like this.
  3. Apr 9, 2017 at 11:13 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Did you do the voice recognition with the head unit..?? That might help.
    Also....Check the tranny fluid level.. Physically....!! do not let the dealer tell you it is OK by hooking up the puter..!!
  4. Apr 9, 2017 at 11:31 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's not just black, black just shows more.
    Paint on almost any modern vehicle is considerably softer than the paints of yore.
    No low/middle class vehicle will have paint durable for 'touch' automated car washes.
    JoeCOVA likes this.
  5. Apr 9, 2017 at 12:13 PM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    silver sky metallic hides any scratches
    The black trim pieces definitely show scratches, but I'm not super worried about it right now. Those are fairly cheap to replace if they start looking too haggard.
  6. Apr 9, 2017 at 3:07 PM
    rosst
    I haven't research this, but I was under the impression the transmission fluid level can only be checked by computer. Is this not true?
  7. Apr 9, 2017 at 4:19 PM
    tacoflavoredkisses1
    It's the exact opposite. It can only be checked manually.
    It's a tedious process--which is why dealers say the computer checks it (because they dont want to).
    ToyoMann likes this.
  8. Apr 10, 2017 at 6:37 AM
    rosst
    Toyota service says the wheel arch trim discoloring is winter "residual". Ok, so it doesn't wipe off or clean up. I guess it's their way of saying tough sh*t, live wih it. I did the voice training with entunes and it still barely works. The voice recognition on my Android phone is 100% better. What was Toyota thinking by eliminating the transmission dip stick?
  9. Apr 10, 2017 at 6:39 AM
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  10. Apr 24, 2017 at 1:37 PM
    ToyoMann
    ToyoMann Well-Known Member
    2017 Tacoma TRD Off Road
    Hello. The shift flare is a valve body design flaw in the transmission. When the fluid cools, an air bubble is drawn into the 4th gear apply clutch circuit. The bubble causes a momentary slip when shifting to 4th gear. Toyota has a software patch that helps by causing the valve body to burp the bubble.
    Here is what to do:
    File a case with Toyota corporate
    Have your fluid level corrected
    Get the latest transmission software flashed. This should help. Good luck!
  11. Apr 24, 2017 at 2:09 PM
    textoy
    textoy Well-Known Member
    Fred
    Texas
    2011 4x4 TRD DC
    no dip stick for the transmission isn't as big a deal as with Porsche where there is not even a dip stick for the engine. I guess the '16's have some transmission problems but my '17 has been great so far. In fact, I don't remember ever adding more than a few ounces of transmission fluid total in all the cars I've owned in the last 50 years.
  12. Apr 24, 2017 at 2:26 PM
    rosst
    I'll check for a reflash. Thanks
  13. Apr 25, 2017 at 12:19 PM
    dsmdylan
    dsmdylan Well-Known Member
    Dallas, TX
    '17 DCSB OR Quicksand
    [CITATION NEEDED]
  14. Apr 25, 2017 at 12:26 PM
    ToyoMann
    Hi Dylan. I will do what I can. My transmission was flaring 3rd to 4th gear shift. After I filed my transmission, the problem improved, but if I let the truck sit overnight it would flare in the morning. I know the transmission fluid contracts when cold, and I read there are some end caps that are known to leak. If I filled my transmission above the end caps, the transmission never flaired. Returning the level to the factory level, I used a Techstream to burp 4th gear apply circuit while the selector was in park. The shift flare never occured when I did this procedure. Thus, I concluded there was leaking down of a circuit in the valve body causing the flare. I hope that helps.
