10k miles on my ‘23 TRD Pro AT
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davidij, Aug 1, 2023.
  1. Aug 1, 2023 at 7:56 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    So far, loving the truck and the slight mods I’ve done:
    1. Dual ARB under hood compressor with under hood switch
    2. Set of Desert Does It seat jackers (life changers)
    3. Set of 5 (replaced spare) BFG KO2s in LT265/75 R16.
    4. Mounting bracket to keep spare in bed of truck; had to buy myself a slider bracket for the back side of the bed since G3 Tacoma don’t come with that bracket. Got it from a gen2 Tacoma and it fit perfectly
    5. Removed predator tube steps (broke my steps off on first off-roading trip)
    6. Ordered new Wescott Designs rock sliders. 20degree with top plates
    What I’m not happy with
    1. Driver Seat in wearing a little more than I would have expected. I’m very good at not ‘sliding out’ but it still shows excessive wear.
    2. I have a center consoles safe that i hate and don’t use. I didn’t even know my build came with it. Unless you absolutely need it, don’t get it.
    3. Lastly, AND THIS IS A BIG ONE, my truck shakes excessively at high speeds. I think it’s the tires and balancing, but I haven’t been able to get them balanced well. So, beware bigger tires may cause this. I’m currently working with dealer to get this resolved
    4. [there are some other things I don’t like, but won’t ‘complain’ because I knew what I was getting]
    Overall, love the truck! Just wish there was a way around the Arizona Pin Stripes because it looks like it is taking a paint beating.
    Junkhead likes this.
  2. Aug 1, 2023 at 8:01 AM
    cowfootball
    cowfootball Well-Known Member
    South Lake Tahoe, CA
    2022 TRD OR
    Doesn't the Pro a have power driver seat?
    LeakyAC likes this.
  3. Aug 1, 2023 at 8:03 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    They also don't come with a console safe lol
    RIX TUX and Road_Warrior like this.
  4. Aug 1, 2023 at 8:04 AM
    cowfootball
    2022 TRD OR
    I don't think any trim does, it's just whether or not the dealer decided to waste some more of your time and money. My TRD OR came with the safe but I pulled it out immediately.
    LeakyAC[QUOTED] likes this.
  5. Aug 1, 2023 at 8:06 AM
    LeakyAC
    Never seen any desler do that up here.
    What a waste of time.
    I also never understood the dealer installed side steps on lifted trucks like TRD pro....why hurt the ground clearance of a lifted truck..makes no sense
  6. Aug 1, 2023 at 8:10 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    it does have power seats, but the jackers still helped my seating position even more.
    Watterdog and LeakyAC like this.
  7. Aug 1, 2023 at 8:13 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    They actually offer this as an option, the safe was a port install not a dealer install [detailed on my window sticker] (a Toyota part). Very good quality and install. It just limits my center console space and now I have two doors to reach through when getting in there. More of a nuisance than a feature for me.
    TnShooter and Road_Warrior like this.
  8. Aug 1, 2023 at 8:14 AM
    cowfootball
    2022 TRD OR
    You can remove it with four screws at the bottom. It comes out very easily.
    davidij[QUOTED][OP] likes this.
  9. Aug 1, 2023 at 8:15 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    … another thing I didn’t know was that I can’t use my center console USB cable for Apple CarPlay. I’m limited to the one under radio. Picky complaint, but…
    LeakyAC likes this.
  10. Aug 1, 2023 at 8:17 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    I’ll likely do this, just been lazy/busy. Anyone interested in buying it. I haven’t even set the combination.
  11. Aug 1, 2023 at 8:19 AM
    davidij
    davidij [OP] Member
    David
    2023 Tacoma TRD Pro
    Yeah, the side steps were a waste for $600+ dollars. They are also shin busters if you are not careful.
    Chew and LeakyAC[QUOTED] like this.
  12. Aug 1, 2023 at 8:23 AM
    happyvirus
    happyvirus Well-Known Member
    If its cheap enough :)
  13. Aug 1, 2023 at 8:25 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    This started with the KO-Bros? If so, who put them on and have you reached back out? I ask because I am on my 2nd set of 265/70-R17 and have been great tires without vibrations are high speeds. Are they louder than OEM, yup, but have been a great tire, so I'm just got them again.
    Thank you for your feedback
  14. Aug 1, 2023 at 8:25 AM
    Clearwater Bill
    Billy
    Largo Florida
    Sounds like you bought from a Gulf States dealer.
    Padding up the profit with fluff is a hallmark of them and SEToyota both.
    LeakyAC likes this.
  15. Aug 1, 2023 at 8:33 AM
    Watterdog
    Watterdog Active Member
    I've got a 2023 TRD OR. It has the power seat, but when I drove it my back and knees got so sore that I thought I'd have to get rid of it, and I felt like I was sitting in a hole. But then I found the seat jackers, lifted the front 1.5 inches and the back 1/2 inch, now it's nearly the most comfortable rig I've ever had and I don't feel like I'm sitting in a hole!
    LeakyAC likes this.
  16. Aug 1, 2023 at 8:54 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    You have leather seats right?
    If you don’t clean them regularly, the soil on the seat is abrasive and will scratch/wear the leather.
    I clean and condition my seat once a week or so and 5 years later it still looks great.
    Tacospike likes this.
  17. Aug 1, 2023 at 9:01 AM
    BigJanko
    BigJanko Well-Known Member
    West Columbia, SC
    2021 Tacoma TRD Pro Matte Sunflower Wrap
    Body Armor Hybrid Front Bumper w/high clearance wings Body Armor Rear Bumper Armordillo Chase Rack Diode Dynamics SS5 Flood Lights Caliraised LED Ditch Lights Rough Country 20" Light Bar Rough Country 2" LED Pods Rough Country 6" LED Bars Glowe Industries Under Glow Kit Barricade 9,500 lb Winch S&B Cold Air Intake OTT Tune N-Fab Sliders PWF Matte Sunflower Vinyl Wrap
    How much you want for it?
  18. Aug 1, 2023 at 9:03 AM
    rip ej1
    rip ej1 Well-Known Member
    Daniel
    NorCal
    2020 AG TRD Pro
    Got any pics of your mounting bracket for the spare? Custom built? I'm looking for ideas...
  19. Aug 1, 2023 at 10:45 AM
    Mbtstaco
    Mbtstaco Well-Known Member
    2023 Tacoma Pro MGM
    Have you driven the truck 10k with excessive shaking? If so that's nuts. I got 5 miles when I switched tires and went right back and handed them the keys.
  20. Aug 1, 2023 at 11:33 AM
    Dark_Taco
    Dark_Taco Well-Known Member
    2023 TRD Pro
    Stock
    What leather conditioner do you use?
