10k oil change??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by failytaco77, Jan 30, 2011.
  1. Jan 30, 2011 at 6:54 PM
    failytaco77
    failytaco77 [OP] Active Member
    jackson,ms
    10 prerunner
    so took my truck to the dealer for its 1st "tune up" (tires rotated and fluids check which took exactly and hr like they told me which quite nice compared to what happens at a chevy dealership like with my last truck) and didnt realize they dont change the oil til 10k since its supposidly synthetic oil. SO my question is should i change it now around 5k since it is after all the 1st 5k miles on the truck?? :confused::confused:
  2. Jan 30, 2011 at 6:57 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    IMO I would never have 10k miles on an oil change.
  3. Jan 30, 2011 at 7:02 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    not sure who told you to change it at 10K, but i never go more than 5...if my dealer told me that, I'd find another service department...
  4. Jan 30, 2011 at 7:06 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Every 5k. No more than that.
  5. Jan 30, 2011 at 7:17 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You have a Maintenance Required Light that'll blink at you when you reach 4500 miles and stay on constant when it reaches 5,000miles (since the last time it was reset). That's set from the factory.
    Are you sure they didn't change the oil? They might have changed it and reset your maintenance required light....and told you that you don't have to change it again until 10K miles.
  6. Jan 30, 2011 at 7:33 PM
    failytaco77
    jackson,ms
    10 prerunner
    yes the maintenance light did go off after they got done but the lady there told me that i supposidly have synthetic oil and it doesnt need to be changed til the 10k service and only the tires were rotated and inspected. But personally i feel somewhat uncomfortable not changing it being its 1st 5k. But will this void the maintenance plan if i go and do this????
  7. Jan 30, 2011 at 7:38 PM
    JKD
    JKD Well-Known Member
    They are mistaken. Toyota released an update that said that the 2.7 can go 10k between changes if you use synthetic oil.
    I emailed Toyota and asked specifically if the 4.0 V6 Tacoma could go 10k miles on synthetic. They said no, they were not changing the 5,000 mile oil change interval on the Tacoma 4.0 V6.
    So unless they've changed something since about 8 months ago, there is no accepted 10k oil change interval for the 4.0 V6 Taco.
    Now, out of warranty...I would not hesitate to extend oil change intervals using synthetic oil and a quality filter, so long as the oil analysis says the oil is not bad.
  8. Jan 30, 2011 at 10:46 PM
    Janster
    Jandy
    Lancaster, PA
    Are you saying the maintenance required light started flashing at you AFTER they performed the work?
    Or are you saying it was flashing BEFORE they performed the work?
    I'm trying to figure out....Did the dealership reset the light and didn't change the oil? If yes...that's total BS.
    I'd trust the maintenance required light before trusting anyone at the dealer. If Toyota changed the interval to 10K - then owners should've received a notice AND Toyota should have the ECM's reflashed to reflect the 10K so our maintenance required lights will go on at the appropriate mileage. Not only that...but you don't know for sure what kind of oil is in them from the factory.
    If your truck has 5,000 miles on it and you've confirmed they DID NOT change the oil..... I would definately change it!!! Look in your owners manual on how to reset the maintenace required light.
  9. Jan 30, 2011 at 11:43 PM
    scottri
    scottri Well-Known Member
    Scott
    Tigard Oregon
    '10 Sport DC TRD Sport PreRunner
    Cover King Seat Covers, WeatherTech Liners, PopNLock, storage bin locks, N-Fab Step bars, and G4 Elite Tonneau cover.
    I do mine every 5K regardless of the type of oil.
  10. Jan 31, 2011 at 12:01 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    PFFFFFF>....
    That is grandpa thinking. Step into the 20th century. Then look towards the 21st.
    I don't think I would ever want to put 10k (assuming miles) on an oil change, but I have done close to just using the oil monitoring system.
    Do your research... don't blindly waste oil.
  11. Jan 31, 2011 at 2:34 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    Your driving pattern should be what determines how often you change your oil. Most quality synthetic oils will do fine running 10K miles. My concern would be why is the dealer telling you to go that long when Toyota specifies 5K. The other question I would be asking is what did they charge you for the service? I think I'd be looking for another service dept. If they're skimping on performing an oil change specified by Toyota that takes 10 minutes to perform, what other services are they cutting corners on?
  12. Jan 31, 2011 at 4:40 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    ^x200^
    The only reason to change oil at 5k is if you worry about warranty coverage being compromised, which itself is not a serious worry because oil related failures just never happen in modern engines. Even those abused with NEVER changing oil in the warranty period!
    But that IS why it's so odd a dealer service department would say that. The only fathomable reason is they are confused with other Toyota models that have been changed to 10k change intervals (Camry for instance).
  13. Jan 31, 2011 at 5:14 AM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I was told to gO 10k by my dealer as well. They put mobil 1 synthetic which should be fine until then.
  14. Jan 31, 2011 at 6:16 AM
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    Found this:
    Tech Tip T-TT-0005-10 says the following:
  15. Jan 31, 2011 at 7:48 AM
    jonny
    jonny Betty White Edition Heep ZJ
    THIS
    my 2010(newer 4.0) fj also has 10k oil changes. kinda scares me...
  16. Jan 31, 2011 at 7:55 AM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    I try to change mine at 3000 miles if I can, then i recycle. I spend about 30 bucks each oil change, but I get to know my truck better by going through all the fluids, checking/ greasing u-joints, diff fluids. I'd like to keep this truck as long as I can.
  17. Jan 31, 2011 at 8:23 AM
    Janster
    Jandy
    Lancaster, PA
    Does your owners manual state this?
    How about your maintenance required light?
  18. Jan 31, 2011 at 8:57 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    Do you have a maintenance contract with the dealer? If so, perhaps the dealer is trying to save money by stretching out the oil change interval...
  19. Jan 31, 2011 at 11:15 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
  20. Jan 31, 2011 at 11:37 AM
    failytaco77
    jackson,ms
    10 prerunner
