10k oil change??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by failytaco77, Jan 30, 2011.
  1. Feb 1, 2011 at 7:48 PM
    #41
    TJ Asher
    TJ Asher Well-Known Member
    TJ
    Minneapolis
    '10 Virgin
    To those who scoff at the 10K + miles between oil changes on synthetic oil, consider this...
    BMW recommends doing oil changes every 15,000 miles on their vehicles. Basically they have a once a year oil change. It is all synthetic oil.
    I've got almost 90K on my MINI and only change oil when the computer in the car tells me to. Averages about every 12,000 miles. Only ever had Castrol Syntec in the crankcase. No problems at all so far... <knocks wood> :)
    My Taco is on a 5K interval with normal oil for now.
  2. Feb 1, 2011 at 8:16 PM
    #42
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    As mentioned b4 in this thread, I'd be more concerned about going 10K on the oil filter than the oil itself.
  3. Feb 1, 2011 at 10:11 PM
    #43
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    BMW vehicles do not have a Toyota 4.0L engine under the hood.... different animal altogether.
    So, in a BMW... what does the oil look like after 15K miles? Is it tan in color or like dark chocolate?
    What does it look like at 5k miles?
  4. Feb 2, 2011 at 4:47 AM
    #44
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    There's not much difference in BMW and Toyota engines as far is this is concerned...internal combustion engines all do pretty much the same thing. If anything, Toyota is much less high-strung and finicky and so would handle it better.
    The real difference is the EU has put terrific pressure on the entire automotive industry value chain to reduce pollution, so auto and oil industry have responded. This pressure has been mounting for quite some time.
    I WOULD look for oils that have BMW 'LL' specification certification (or VW 502 specification) if you want to do this though. It seriously makes a difference for long drain intervals. Those oils will probably be in 0w40 or 5w40 weight though...an that WILL make a difference because Toyota designers seem to have gone the low-viscosity approach favoring fuel economy.
    You'll be left on your own to find a low-vis oil with good long service life properties. (Penn Platinum is one...as is Mobil1 extended drain)
    Color prolly will be dark when you drain, but that's perfectly OK. It shows the oil is doing it's job. Looking at oil color to infer anything is just another of those old-wife tale things that should be forgotten.
  5. Feb 2, 2011 at 4:58 AM
    #45
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    I think one of the reasons Toyota is sticking with the 5K interval is Toyota engine sludging is still fresh in some consumers minds. The last thig Toyota needs right now is a mass recall for engine problems; therefore they tend to keep it on the conservative/safe side. There have been several folks over on BITOG who have run 10K intervals on the 4.0 without any issues and Blackstone lab results to prove it is safe. As someone else has stated, the couple a quality synthetic with a quality oil filter and you should be fine for 10K miles. Suprised to see some folks sticking to the 3K OCI....I guess old habits are hard to break?
  6. Feb 2, 2011 at 4:58 AM
    #46
    buddywh1
    Philly PA
    07 DC SR5 4x4
    It's not the oil filter that matters. There should be no reason for the oil filter to be catching stuff by 200 miles or so after oil change. If it is then the engine is making hunks of metal and you're f*cked.
    What does matter is the air filter...if it's bad then dust/sand drawn in is blown by the rings so the oil filter has to catch it. Keep your air filter fresh and everything tight and well sealed on the intake and you'll be good.
    Oh...and throw away that K&N PoS if you got one...they do nothing but harm.
  7. Feb 2, 2011 at 5:02 AM
    #47
    steviestyles
    Colorado Springs
    Bone Stock
    Yeah the Air Filter probably matters more than an oil filter in retrospect; however the oil filter is cheap insurance. As you've said most oil filters don't trap dirt and particles to capacity. If so, then you're right if you have massive chuncks of metal in your filter than you have bigger problems. In racing and extreme engine applications, some choose to bypass an oil filter in favor of oil flow with little to no issues. However for $5-$10 you can get a decent filter capable of running for 10K miles
  8. Feb 2, 2011 at 6:39 AM
    #48
    Janster
    Jandy
    Lancaster, PA
    Not a wise tale....atleast not for me.
    Synthetic oils are good at 'cleansing' and removing dirt/sludge. My oil is really really dark after 5K miles (like dark chocolate). That tells me, its DIRTY oil. Personally for me - my oil is already dirty at 5K miles, I'm not leaving that dirty oil in there for another 5k miles.
  9. Feb 2, 2011 at 7:17 AM
    #49
    buddywh1
    Philly PA
    07 DC SR5 4x4
    The idea is not to let the sludge be formed in the first place. THAT is what ANY modern detergent oil excels at... even petroleum oils... holding the dirt and carbon in suspension. So they look dirty...and the engine is clean!
  10. Feb 2, 2011 at 7:38 AM
    #50
    ckeeton
    ckeeton Bazinga
    Duluth, GA
    2011 DC Trd Sport Gray
    trd sport with avid off road light bar, avid rock sliders. OEM roof rack, 12' LED light bar, and Sock monkey decals.
    haha i feel you on that man. got the 11 DC sport too. and plan on adding the rack soon too. but yeah i am always planning to change or add things to it. doesnt help that im in college without a job during the year
  11. Sep 20, 2021 at 8:40 AM
    #51
    jtaco11
    jtaco11 Well-Known Member
    its 2021 and 10k oil changes seems pretty normal. most newer cars doing it w 0w16/0w20. newer synthetics oils/filters rated 10k+ miles. curious if anyone been doing 10k oil changes consistently on 2nd gen.
    heres the debate...
    oil so cheap just do it at 5k
    go by the manual 5k or 7k or 6 mths
    why change so early when synthetic oil/filter is rated +10k miles
  12. Sep 20, 2021 at 8:42 AM
    #52
    cryptolyme
    cryptolyme Well-Known Member
    Virginia
    2021 SR Access Cab 4x4 2.7L
    i change mine before 5000 miles just because engine break-in. then i'll take it to the dealer for the 10k service. also changed the rear diff fluid at 1500 miles and it was pretty nasty.
  13. Sep 20, 2021 at 8:43 AM
    #53
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Dang, reviving a 10 year old thread
  14. Sep 20, 2021 at 8:44 AM
    #54
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Brought back from 2011. Oil threads never die.
    tacoman45 likes this.
  15. Sep 20, 2021 at 8:57 AM
    #55
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Sadly they never die.....and unfortunately never stop being born either.
    That said....the reason Toyota never officially adopted a 10k OCI on the 4.0 single VVT-i is because the recommended weight is 5w30. 5w30 GTMO is conventional. The average person wouldn't know whether they have conventional, blend or synthetic in their engine. So to avoid the possibility of someone idling in stop and go city traffic for 10k miles on a conventional oil, they just kept the OCI at 5k. The dual VVT-i 1GR 4.0 does recommend 0w20 and 10k OCIs.
    Same reason Toyota engines that recommend 0w20 (which is only synthetic) are cautioned to have the oil changed from 5w20 back to 0w20 "at the next OC". Because 5w20s are available in conventional, blends and synthetics. The owner may not know what they have. If you know for a fact that the 5w20 you're running is fully synthetic then it's your choice to leave it in there for 10k if you want
    Otto Mation and MattCowsmasher like this.
  16. Sep 20, 2021 at 9:01 AM
    #56
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    I’ve got 10k on my previous trucks without issue this I don’t the filter is to small imho. If one decides to go 10k id change the filter at 5k at least.
  17. Sep 20, 2021 at 9:05 AM
    #57
    jtaco11
    mobil 1 oil filters 1 yr or 20k. even the super tech filter fr walmart has 10k miles.
  18. Sep 20, 2021 at 9:16 AM
    #58
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    This is great information.
    Hey when are you picking up the Pro Grille?
  19. Sep 20, 2021 at 9:43 AM
    #59
    Plain Jane Taco
    USA
    I'm still trying to gather up the funds. I'm 2/3 of the way there. You don't mind most of it in quarters and dimes do you?
    :anonymous:
  20. Sep 20, 2021 at 10:17 AM
    #60
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    You can quarter and dime me, just don’t nickel and dime me.
