10mi of 4x4 per month - According to Manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by fireberd350, Mar 6, 2016.
  1. Mar 6, 2016 at 6:18 AM
    fireberd350
    fireberd350 [OP] Well-Known Member
    West Chester, PA
    2016 TRD Sport
    Read through the manual and it recommends 10mi of 4x4 / mo to keep the system lubricated. This is my first 4x4. What's the real world recommendation? Pg 247
  2. Mar 6, 2016 at 6:21 AM
    KILLINTIME
    KILLINTIME Like a Villain
  3. Mar 6, 2016 at 6:22 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    10 miles....straight if on paved road.
    If you turned sharp in a paved road you'll probably blow the transfer case from it binding on the pavement.
    Dirt road is the best if your going to turn and pretty much any "off road" environment.
  4. Mar 6, 2016 at 6:32 AM
    Large
    Large Red
    Real world would be the 10 miles a month. I actually find it better to do it in short bursts, say on a straight road where the speed limit is around 30 mph. The actuators like to fail in the second gen if you don't use them often. I would turn it on a few times a week for 1/4 to 1/2 a mile at a time.
    ramonortiz55 likes this.
  5. Mar 6, 2016 at 6:42 AM
    keithert
    keithert Well-Known Member
    I've wondered about this. Isn't the ftont driveshaft and diff turning all the time? They just are not powered until 4x4 is turned on.
    vinkon235 and little_mule like this.
  6. Mar 6, 2016 at 6:46 AM
    WIDGIN9
    WIDGIN9 Well-Known Member
    Earth, I think.
    2016 MGM 4x4 Limited, 2001 Black 4x4 SR5 Doublecab
    NRA Life Member Sticker, Body Armor 4x4 Step Rail, Leer Trilogy Bed Cover
    Turn it on for a mile or so in a straight line whenever it rains.
    JoeRacer302 likes this.
  7. Mar 6, 2016 at 6:49 AM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Or snow :thumbsup:
  8. Mar 6, 2016 at 7:40 AM
    AFMurse2014
    AFMurse2014 Death Can Wait
    Devin
    San Antonio
    2016 MGM Double Cab TRD OFF ROAD 6 Speed MANUAL
    Freedom, American flags and ISIS blood Morimoto 35w 5500k HID/ LED highs from TRS. RCI expo rack Core Short throw shifter, hypertech speedo recalibrator. Rear seat molle panel. OVT. PnP 2LM. C4 Hybrid Bumper w/ amber BD squadron pods. 33 pizza cutters. T9 radio
    Yea that's what I was wondering... On my Bronco with manual hubs it was more necessary... As nothing spun from t case forward.
  9. Mar 6, 2016 at 7:40 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Actually, no. The front drive shaft is not engaged until the trasfer case is activated. And like your engine that oil rest at the bottom of the case and doesn't reach all the gears unless activated.
    Had a buddy never do the ten mile rule and ended up needing four wheel drive, engaged it, hit the gas and kaboom. Case gears were so dry it just disintegrated under stress.
  10. Mar 6, 2016 at 7:44 AM
    AFMurse2014
    Devin
    San Antonio
    If the front diff is turning... So is the driveshaft...
  11. Mar 6, 2016 at 7:44 AM
    keithert
    Is that true of the transfer case only? Aren't the diff and driveshaft turning whenever the wheels are turning?
  12. Mar 6, 2016 at 7:45 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Ummmmm. o_O
    Mnewman03 likes this.
  13. Mar 6, 2016 at 7:45 AM
    AFMurse2014
    Devin
    San Antonio
    It's more so to ensure the t case is properly lubed. Most likely the seals and bearings on the front output shaft side. And to keep electronic parts from seizing
    vinkon235 likes this.
  14. Mar 6, 2016 at 7:46 AM
    AFMurse2014
    Devin
    San Antonio
    If Toyota was smart they'd have a splash ring on both output shafts so regardless of 2 or 4 it'd still get splashed..
    (They may already have this, I never opened a Toyota case)
  15. Mar 6, 2016 at 7:53 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    Here, I'll help you out. This is an example of gears in a transfer case. This is particularly a 4Runner transfer case. If these don't have proper lubrication, under stress they have a high probability of failure. image.jpg
  16. Mar 6, 2016 at 7:59 AM
    Boone
    Boone, NC
    Airbags deployed
    Gears don't magically become brittle to the point of "disintegrating" due to lack of lubrication.
  17. Mar 6, 2016 at 8:00 AM
    AFMurse2014
    Devin
    San Antonio
    Here my issue though.. The front shaft IS spinning. But the gear it's attached to is not connected to the output of the rear shaft so it's essentially in neutral.
    Imagine this video with an actual drive shaft. That lower gear would still be spinning if the vehicle is moving due to input front the shaft
    https://youtu.be/VxWIW_i72Ec
  18. Mar 6, 2016 at 8:02 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    You are correct, but they do require proper maintence before you need them.
    Yeah your rear diff will operate for a variable amount of time without lube, but that is drastically reduced without it.
    The oils used in all vehicles function on a molecular level to protect the metal to metal functions of these gears under all stresses.
    And being that the story I mentioned he NEVER engaged the four wheel drive. And when he did, the case was basically seized.
    Boone[QUOTED] likes this.
  19. Mar 6, 2016 at 8:04 AM
    Hondah
    Newnan, Ga
    '13 RC 4x4
    This is great!
    AFMurse2014[QUOTED] likes this.
  20. Mar 6, 2016 at 8:35 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Its to exercise the actuator no ?
