10mm lift enhancer doesn't line up on Stock Spline - WTF
Discussion in 'Suspension' started by 1expensiveTaco, May 11, 2012.
  1. May 11, 2012 at 6:06 PM
    1expensiveTaco
    1expensiveTaco [OP] Active Member
    Steven
    Washington
    07 Tacoma Access Cab 4x4 V6
    In the middle of lifting my truck;
    1)OME 90000 Nitro Charger Shocks
    2)OME 885 Coils
    3)10mm Lift Enhancer
    In The Rear (ha)
    4)OME Dakar Leaf Spring (CSO47R)
    5)OME 182 shocks
    6)Toyotec 3 Degree Axel Shims
    7)OME Drive shaft Packer Kit (FK29)
    8)New U-Bolts, New Toyota Bushings
    Got the rear done, working on the front, put new bolts in stock spline to compensate for 10mm lift enhancer went to put the damn thing on and it didn't line up:
    The old
    What happens when you try to use a vice and an extended socket to press bolts into a spline
    Old spline new bolts
    Doesn't line up
    Anything might help please shoot your expertise at me. I have axle shims and a drive shaft spacer kit installed will excluding the 10mm enhancer f anything up? I don't mind buying new spindles - suggestions? It seems the lift enhancer is the problem ti me though. Thanks for any and all advise.
  2. May 11, 2012 at 6:16 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Looks to be the wrong one?
    That sucks man!
  3. May 11, 2012 at 6:22 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Did you try installing the spacer on the stock bolts before you removed them? Or to put it another way, are you sure the installation process didn't get the new bolts out of whack?
  4. May 11, 2012 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would drill out the holes to size/fit.
  5. May 11, 2012 at 6:29 PM
    1expensiveTaco
    Steven
    Washington
    I unfortunately did not try to put on with stock bolts, but i can, in process of removing second coil/shock - bolts are sound thankfully despite the process in which they were put on; i ended up using a screw to pull the bolts threw so there wasn't adverse pressure to cause damage.
    just tried and the spacer does not fit on original bolts
  6. May 11, 2012 at 6:30 PM
    1expensiveTaco
    Steven
    Washington
    I thought about this... i feel like the holes would rupture the circumference of the spacer. and then id be fd
  7. May 11, 2012 at 6:33 PM
    1expensiveTaco
    Steven
    Washington
    could be.....
    I bought them from I figured this would be accounted for....
  8. May 11, 2012 at 7:15 PM
    BillJC
    BillJC Well-Known Member
    Bill
    Novato, CA
    2011 White SR5 DCLB 4x4
    So?
    These are the Toytec ones I installed. [​IMG]
  9. May 11, 2012 at 7:19 PM
    1expensiveTaco
    Steven
    Washington
    lol well then maybe i should get on it.
  10. May 11, 2012 at 9:08 PM
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Before you assemble everything, see if the spline matches up to the bracket on the truck as well. If the new bolts have been bent too much they might need some "massaging" to get in there as well.
  11. May 11, 2012 at 9:13 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    looks like you got first gen spacer instead of 2nd gen. I'd grab a grinder and a cut off wheel and make them fit. Once it's all bolted down and the weight of the truck is on it you'll be fine.
  12. May 12, 2012 at 6:29 AM
    SManZ
    Fauquier County, VA
    Next time, try tapping the backside in with a hammer instead of squashing it in with a vise. Constant increasing force is a lot harder on parts than multiple sharp impacts. You might be suprised how easy they are to install with a mallet. I've swapped these studs out before too :)
  13. May 12, 2012 at 8:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They look like the right ones, just the longer bolts might be cocked a bit.
    Or run some washers, and nuts down the threads, and tighten the nuts, allowing them to pull the studs into place.
  14. May 12, 2012 at 9:06 PM
    1expensiveTaco
    Steven
    Washington
    Thanks everyone I ended up cutting them to fit, lift fully installed pictures asap.
  15. May 12, 2012 at 9:10 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    IIRC the bolt pattern between first and 2nd gens is different, ever so slightly. Looks like you might have gotten a first gen top spacer.
    Or at least thats what I came up with when I measured mine and Eric's 1st gen before he cut my top plates.
  16. May 12, 2012 at 9:17 PM
    1expensiveTaco
    Steven
    Washington
    Not the best cuts but it got the job done
