10w-30 or 5w-30 for high mileage 1995 V6?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 95TacomaNewb, Dec 14, 2024.
  1. Dec 14, 2024 at 4:14 PM
    95TacomaNewb
    95TacomaNewb [OP] Well-Known Member
    1995 Taco, V6 Supercharged, 4x4 Manual
    From what I've read 5w-30 is better for colder climates, but is there a reason not to use it in warmer climates? I'm in Northern California so typically a warm climate, but sometimes go over the hill into the Tahoe area where it can get colder.
    1995 V6 4x4
  2. Dec 14, 2024 at 5:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    Whatever it says on your oil cap......
    95TacomaNewb[OP] likes this.
  3. Dec 14, 2024 at 5:28 PM
    02hilux
    Planet: EARTH
    5w30
    95TacomaNewb[OP] and leid like this.
  4. Dec 14, 2024 at 5:30 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    -Rorschach- likes this.
  5. Dec 14, 2024 at 5:37 PM
    WheelinDev
    WheelinDev Active Member
    2020 TRD Pro
    With conventional oils they had to put in more additives to make the 5W rating which technically would've slightly changed how the oils acted at operating temp vs 10w but even then not enough to make any difference.
    With the new synthetics they're exactly the same at operating temp and the only difference is how they flow when cold.
    https://bobistheoilguy.com/forums/threads/reason-to-not-use-5w-30-over-10w-30.158895/post-2335884
    If I were in your shoes I'd just run 5w-30 all the time.
  6. Dec 14, 2024 at 6:48 PM
    95TacomaNewb
    Thank you
