10w 30 v 5w; any difference?
Discussion in '1st Gen. Tacomas (1995-2004)' started by beedoola, Jun 22, 2012.
  1. Jun 22, 2012 at 11:19 AM
    beedoola
    beedoola [OP] Well-Known Member
    San Francisco, CA
    01' Tacoma PreRunner 2.7
    Owner's manual calls for 5w 30 which I've used to change my oil - using synthetic. My boss bought some Mobil one 10w synthetic on sale and offered it to me. Is it alright to use the 10? I have 141k on my taco: 01' prerunner, ; cycl. 2.7
  2. Jun 22, 2012 at 11:32 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Go for it.
  3. Jun 22, 2012 at 11:34 AM
    jsmarine
    jsmarine Well-Known Member
    Jeff
    Dallas, TX
    2005 Tacoma SR5 Crew Cab 4x4
    ARB front & rear lockers ARB bull bar Warn XP9000 winch IPF lights
    Yep, go for it. You will be just fine.
  4. Jun 22, 2012 at 3:01 PM
    ailll1
    ailll1 Well-Known Member
    Alex
    Québec, Canada
    2016 Tacoma Trd Sport Double cab
    The 10w30 is just thicker oil at low temp compared to 5w30. I dont how cold it gets in San Francisco but 10w30 oil shouldnt be a problem
  5. Jun 22, 2012 at 3:34 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    No noticeable difference whatsoever.
    I use ONLY Rotella synthetic T6 5-40 in mine, best oil out there, go to Bob the oil guys website and look it up!
  6. Jun 22, 2012 at 3:54 PM
    J Gibson
    J Gibson Well-Known Member
    J
    Knoxville, TN
    '12 DCSB,4wd,TRD Sport, tow pkg, MGM
    katzkin leather, toyota step bars, pro grill, advent overhead DVD player, cargo extender, bed mat, husky liners, impulse digital brake controller, avs bugflector, tinted windows, Firestone ride-rite air bags, ARE camper top with tool doors, ScangaugeII, ProEFX tow mirrors, ImMrYo rearview mirror lift bracket, Salex glove box and console organizers, 2020 Tacoma Pro styled wheels, 265/70 r17 Michelin MS2 tires, LED map lights, drivers seat extended and raised, ram ball tech deck installed, blacked out badges, tinted taillights, upgraded climate control knobs, ultimate headlight upgrade with Osram superbrights and wiring harness along wit OEM pro headlight housings.
    I concur. Especially in the summer the thicker oil will be OK.
  7. Jun 22, 2012 at 3:57 PM
    jandrews
    '09 FourDubDee TRD OR
    Your truck gon' blow up.
  8. Jun 22, 2012 at 3:59 PM
    scocar
    scocar Patron of the Farts
    The 01 owner's manual shows both, depending on anticipated temprature range, but with a ton of overlap. Dont' have it in front of me, but bascically, you'd only have to use 5 if you had regularly freezing, and only have to use 10 if you were regularly over 100 or desert.
  9. Apr 21, 2013 at 10:30 AM
    strangeland
    strangeland Member
    baffin island
    her name is yoru 4x4 2.7l
    I Never run 10-w30 conventional because the oil industry uses this grade in particular to get rid of its low grade bases( I, II ) . Other conventional grades are usually (II & III's) but since your running synthetic it should be Almost all grade(IV)bases.
  10. Apr 21, 2013 at 3:07 PM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Have you done uoa's to prove its the best? Even if you compair the same engines I can almost be certain all will have different wear numbers.
  11. Apr 22, 2013 at 12:59 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    unless it makes a mpg difference that is worth it or you're keeping your engine 500K miles it's a waste of money. I've known people that used conventional, average cheap motor oil and tore their engines down after $200K miles and it looked great. I'm not advocating conventional oil, just making a point.
    Rachelsdaddy likes this.
  12. Sep 16, 2021 at 4:51 PM
    GermanTickler
    GermanTickler Active Member
    2009 toyota tacoma
    so with 250k miles 5w-30 or 10-30 2.7 Tacoma? burns a quart every 1500 miles
  13. Sep 17, 2021 at 7:01 AM
    jarvis
    jarvis Well-Known Member
    Pahrump Nevada
    2003 Xtra Cab Prerunner
    When I lived in San Diego I was at a Toyota dealer and their oil was on sale. A mech told me to use 10W30 and that it would NOT hurt the engine at all.
  14. Sep 17, 2021 at 8:15 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Fix your rings and seals and it doesn't matter what oil you run.
    Bivouac likes this.
