10w30 synthetic?
Discussion in 'Performance and Tuning' started by eric3187, Mar 15, 2013.
  1. Mar 15, 2013 at 9:39 AM
    eric3187
    eric3187 [OP] Well-Known Member
    been running 5w30, but i have enough of royal purple 10w30(acquired it from my grandpa who was friends with the owner/founder of RP) to do the next oil change.
    i am trying to be frugal and use what i have, is there any reason i shouldnt use 10w30?
    about 18k miles on a 4.0L
    driving conditions for this next oil change will be extreme highway miles (800+ miles at a time) as well as offroading when i start my road trip.
    rather than start a new thread... i also have 75w90 RP gear oil, should be good to go for front/rear diffs correct? (e locker rear) TRD O/R
  2. Mar 16, 2013 at 8:16 AM
    bubba353z
    bubba353z Titles? We don't need no stinkin' titles.
    Columbus, Oh
    Former owner of a 12 TRD Sport AC 4x4
    I don't think the 10w30 will hurt anything - go for it.
    If you are in a real cold climate it may start a little slower in the morning.
  3. Mar 16, 2013 at 12:48 PM
    eric3187
    shoot, its already predicted to be in the 90*s this week in houston. 10w30 it is!
    Thanks.
  4. Mar 16, 2013 at 12:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Specified oil for the 2nd Gen is 0w20, 5w20, and 5w30 on some models.
    I wouldn't use it.
    But I wouldn't use RP in any weight, even if it is free.
  5. Mar 16, 2013 at 1:01 PM
    eric3187
    any reason why you would not use it?
  6. Mar 16, 2013 at 1:03 PM
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I was am using 10w 30 Pennzoil full synthetic high mileage.. no problems
  7. Mar 16, 2013 at 1:06 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I experimented with a number of different oils in my motorcycle a few years ago.
    RP did not maintain viscosity any better than Castrol GTX. Mobil-1 and Amsoil held grade for 6000 miles. RP dropped from 20w50 to a 30wt in 2000 miles.
    RP spends more money on marketing and product placement on TV shows than they do on developing a good product.
  8. Mar 16, 2013 at 1:14 PM
    eric3187
    interesting. would you feel the same results would be had with gear oil?
  9. Mar 16, 2013 at 1:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    No clue... I haven't run any tests on gear oils.
  10. Mar 2, 2014 at 12:12 PM
    CampGuy
    CampGuy Well-Known Member
    Dmitry
    California
    2013 4x4 TRD-Sport
    Good Thread!!
  11. Mar 2, 2014 at 12:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I was told if the outside air temp is 60 degrees or above a straight 30w is fine.
  12. Mar 4, 2014 at 7:28 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Redline 5w-40 or 10w-40. Done. Take that fuel wash. :p
  13. Mar 4, 2014 at 7:32 PM
    TripleThreat
    TripleThreat Vance@freevancewriting.com
    They keep callin me cowboy but its not my name...
    Socal but I am still a southern Florida guy
    Toyota Tacoma 4x4 slightly modified
    nothing special.... wanna race?
    What do you mean by red line and we can put 10w-40 since when?
  14. Mar 4, 2014 at 7:46 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    www.redlineoil.com
    These newer trucks that say 0w-20, I'd go with a 30. I've been running a 40 since I purchased my truck in '06.
  15. Mar 5, 2014 at 6:38 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    You can always vary the weight, it's a trade-off between pumpability and film coverage. Now, for maintaining warrantee, and proof, you should stick with the recommended, outside of this, it's what fits your needs.
    Personally, I use 0W30 in my 09 4.0.
  16. Mar 5, 2014 at 7:15 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Very true.
