10w40
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GermanTickler, Dec 27, 2022.
  1. Dec 27, 2022 at 9:53 AM
    GermanTickler
    GermanTickler [OP] Active Member
    2009 toyota tacoma
    Can the VVt system on the 2.7 handle 10w40? Been running 10w30 with no issues. Appreciate it
  2. Dec 27, 2022 at 10:00 AM
    Bishop84
    Bishop84 Well-Known Member
    Yup, no reason to 40 unless you’re in a balls hot climate though.
    If you see cold weather, it needs to be 5w30 or 0w20 ideally.
  3. Dec 27, 2022 at 10:06 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Compare the cSt @ 100*C values of the oils. There are "thick" 10w30s that end up thicker than a "light" 10w40.
    But why deviate from factory spec? The engineers knew what they were doing.
  4. Dec 27, 2022 at 5:18 PM
    GermanTickler
    2009 toyota tacoma
    I have a lot of miles 300 k and it runs better with the thicker oil
  5. Dec 27, 2022 at 5:32 PM
    Bishop84
    I wouldnt simply due to thin passages on the VVTI system. I'd only recommend 10W40 for Arizona or Mexico with the 2.7
    I've worked on Toyotas a long time, 5W30 would benefit your truck more than 10W40. The easier start up with better cold weather rating in the morning puts less strain on an older engine.
  6. Dec 27, 2022 at 5:56 PM
    GermanTickler
    2009 toyota tacoma
    Thanks guys, was just curious
  7. Dec 27, 2022 at 6:13 PM
    GermanTickler
    2009 toyota tacoma
    I have been liking how my truck is running on 10w30 and I use hyperlube which helps with the cold start ups. You think it's ok? I won't go back to 5w20 but might go back to 5w30 if you think that's better @Bishop84
    Bishop84 likes this.
  8. Dec 27, 2022 at 6:16 PM
    Bishop84
    Yea 30 is fine, the 2.7 is a trusty work horse and the 30 makes more sense in your mileage case.
    5w30 would be great.
  9. Dec 27, 2022 at 6:36 PM
    GermanTickler
    2009 toyota tacoma
    I'm amazed how much of a workhorse it is. It runs strong and no signs of slowing down.
  10. Dec 27, 2022 at 6:53 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Define "runs better"...
    SR-71A and Sprig like this.
  11. Dec 28, 2022 at 5:41 AM
    TacoTuesday1
    FL
    why would anyone chose 10w cold when there is 0w and 5w
    GermanTickler[OP] likes this.
  12. Dec 28, 2022 at 6:41 AM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I ran Mobil 1 0W-40 a couple of oil changes. Worked fine, but really no need to deviate from the factory 5w-30.
  13. Dec 29, 2022 at 9:23 AM
    GermanTickler
    2009 toyota tacoma
    I'll use 5w30. Has anyone ever used 5w40? any benefit besides summer time?
  14. Dec 29, 2022 at 9:28 AM
    GermanTickler
    2009 toyota tacoma
    Is full synthetic or synthetic blend better for higher miles? I change my oil every 3k.
  15. Dec 29, 2022 at 9:41 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    You'd think so, but not always. Although I would think Toyota engineers are well seasoned.
  16. Dec 29, 2022 at 10:22 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Still waiting for someone to define “runs better”. Over the years in numerous vehicles Ive run dozens of different oils and viscosities and I’ve never noticed a vehicle or engine actually running better or differently due to the oil I was using. It may actually be performing better in some small way but nothing you could actually see or feel.
    In any event we will never ever ever agree on the best oil to use in any vehicle.
  17. Dec 29, 2022 at 1:12 PM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    What does the owner's manual say? No need to second guess the engineers...
  18. Dec 29, 2022 at 3:17 PM
    GermanTickler
    2009 toyota tacoma
    Yeah I don't think it matters. Kind of done with the the oil weight discussion. Thanks for the feedback
  19. Dec 29, 2022 at 3:24 PM
    GermanTickler
    2009 toyota tacoma
    @Bishop84 Synthetic vs synthetic blend for 3k interval's?
  20. Dec 29, 2022 at 3:55 PM
    Bishop84
    5k synthetic. It’s been proven that dumping good oil early doesn’t do any good.
    Honestly bulk cheap oil is all it needs, whatever 5w30 is on sale.
    These engines only fail from low oil, not oil quality.
