11,000 miles Clutch Failure?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by spivey6690, Aug 5, 2018.
  1. Aug 7, 2018 at 6:49 AM
    #81
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The only way you can start in 2nd with minimal clutch wear is to be rolling when you let out the clutch. If you often start in 2nd from a stop you will definitely shorten the clutch life. That's why Toyota gave you first gear!
    I have personally seen a new vehicle with 36 miles have the clutch completely gone. Person thought every time the brake was needed the clutch needed to be depressed a bit... the first 30 miles was on twisty slow mountain roads.
    shakerhood likes this.
  2. Aug 7, 2018 at 8:48 AM
    #82
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Lol stories like that are why dealerships almost never cover clutches...and to be honest I don't blame them. I'd be saying the same shit if I sold someone a manual car and they brought it back a short time later wanting me to replace the clutch.
    hiPSI[QUOTED] likes this.
  3. Aug 7, 2018 at 9:08 AM
    #83
    Jaque8
    Jaque8 Well-Known Member
    2017 Inferno TRD OR
    Another brand new account with no post history with claims that don't really add up hhhhhmmmmmm.......
    I know this much he's lying about what he drives because the DCLB doesn't come in a manual transmission.
  4. Aug 7, 2018 at 9:23 AM
    #84
    Doggman
    Alabama
    2017 TRD OR MT
    Haha perhaps but I'd guess he has short bed and thinks it's 6'
    MOC221_ likes this.
  5. Aug 7, 2018 at 11:09 AM
    #85
    spivey6690
    spivey6690 [OP] Member
    TRD Sport Double Cab V6 4x4 MT
    Wait...me?
  6. Aug 7, 2018 at 11:10 AM
    #86
    spivey6690
    This is probably true. Whoops.
  7. Aug 7, 2018 at 11:15 AM
    #87
    spivey6690
    Okay fixed. But what claims are not adding up? So far, I see absolutely no reason why my clutch wore out at 11,000 miles.
  8. Aug 7, 2018 at 1:47 PM
    #88
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Logix dictates it can only be two reasons:
    1. You can't drive, or
    2. It was defective.
    None of us have no clue which it is. You could be the worst stickshift handler ever or you might be a pro. Who knows.
    But, we all know wear parts are not covered by basic warranty.
    Personally, i would get a URD, pay someone to install it and move on.
  9. Aug 7, 2018 at 2:16 PM
    #89
    spivey6690
    I’ll try the other option: have Toyota fix it.
    xxTacocaTxx and NUMMI TACOMA like this.
  10. Aug 7, 2018 at 2:18 PM
    #90
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    The options were for failures. The opinion was for what I would do if Toyota follows protocol. Good luck.
  11. Aug 7, 2018 at 2:32 PM
    #91
    Jaque8
    2017 Inferno TRD OR
    I do... user error.
    Thats really the only way to wear out a clutch that fast without exhibiting obvious symptoms prior to failure.
    BillsSR5 likes this.
  12. Aug 7, 2018 at 3:47 PM
    #92
    bijick
    bijick such mods much want
    E
    Stl
    2013 MGM Singular Cabular Selectable
    OME 884’s ,Dakar hd’s, Jba uca, lce header, 4.88’s, Arb locker , j shift tcase-T4R, arb bumper, leer topper, 3500w inverter, mad wife, scratched paint, skid plates, snorkelerer, led flush mount reverse lights, etc..
    The superior Tacoma does.
    Jokes aside it probably does, almost any computer controlled car does.
  13. Aug 7, 2018 at 4:38 PM
    #93
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If a superior Tacoma is plagued with frame rot problems then I guess we’re all doomed. :anonymous:
    All jokes aside the 3rd gen will probably have them too... :poking:
  14. Aug 7, 2018 at 5:39 PM
    #94
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    If i understand you correctly - you're driving and it's a red light ahead so you let off the accelerator, gravity is doing it's work slowing you down, but you want to slow down faster so instead of applying the brakes, you clutch in, shift to a lower gear and release clutch. The reduced gear will catch and cause the truck to slow down and then you do it again and again not applying the brakes ever.
    If that's what you mean, who the fuck does that?
    because of the very poor rev match i've stopped attempting very early when I got my truck. I use the brakes normal and downshift within the speeds that wont' cause it to jerk.
    let's see, other things.. I don't keep the clutch in when I'm stopped at a light.
  15. Aug 7, 2018 at 5:46 PM
    #95
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    I pretty much do the same thing you do. The scenario I was describing is where you are rolling to a stop with the clutch pedal engaged, then you release the clutch pedal about half way to partially engage the gear you are already in, then press the pedal back down when you come to a stop. It's called clutch-braking. The manual warns against doing it. IDKWTFDT.
  16. Aug 7, 2018 at 5:52 PM
    #96
    venezian
    Los Angeles
    2022 7545E
    I get it now. yea, not cool to do that.. That's why I stay put once I stop at a light because all the auto do the creep forward after a stop and there's always a big gap, but i'm not going to engage just to move 10 feet forward.
    MOC221_ likes this.
  17. Aug 8, 2018 at 3:37 PM
    #97
    spivey6690
    Update: Dealer got in touch with Toyota. Toyota is replacing entire clutch assembly (pressure plate, clutch disc, flywheel, etc.). Pretty awesome of them, and they will continue to earn my business no doubt.
  18. Aug 8, 2018 at 3:46 PM
    #98
    su.b.rat
    su.b.rat broken truck
    wow, so you're the guy who got a warrantied clutch replacement. good work!
  19. Aug 8, 2018 at 3:52 PM
    #99
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Someone on here WILL demand to see your paperwork as proof Toyota replaced your clutch for free. I just know it.
    :rolleyes:
    Anyway, hope you get fixed up ASAP :)
  20. Aug 8, 2018 at 4:10 PM
    #100
    Idahobound
    Idahobound Well-Known Member
    Jarrod
    2017 Grey Tacoma TRD sport
    You have 275k on a 2017. Wow
