'11 Black exhaust, don't get it
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheSchwartz, Sep 27, 2010.
  1. Sep 27, 2010 at 12:34 PM
    TheSchwartz
    TheSchwartz [OP] Well-Known Member
    Aaron
    Smithsburg, MD
    '11 DC/LB SR5 Magnetic Gray
    Avid BullBar, BFG 265/75R16, remote car starter, Slim's HID heads and fogs
    So on my '09 taco at around 5k I started to notice that the inner area of the tail pipe was black with suit and that there would occasionally be black splatter on my mud flap. I always chalked it up to my K&N CAI and my exhaust. Now on my '11 with around 1000mi i am noticing the same thing. I did a little reading and found that Toyota recommends nothing lower then 87 octane (which i use) but that all tests were conducted with 91 octane. Also i have been getting about 16MPG around town and HWY. Suggested is between 16 town and 20 HWY. The only thing deviant from stock on this truck is the 265/75R16 that I had the dealer switch over from my old truck.
    My question is could burning a lower octane then testing cause this effect since higher octane only matters during periods of high RPM? and has anyone else experienced this problem?
    Im planing on going to the dealer for a few items and will be having them reset the computer for the tire size and to run a diagnostic.
  2. Sep 27, 2010 at 12:56 PM
    tacobox
    tacobox Evasive Maneuvers PMKMS
    All vehicles come very rich (fuel) from the factory. The black soot is a good thing. The earlier 2nd gens run smoother and get better MPG with higher octane. (Lots of opinions on this). My take is with higher oct the ecu goes to a more agressive timing map and creating more efficent combustion. I use 93 all the time now.
    To test, you could fill up 91or 93, clean the inside of the tail pipe and see if you get the same results as with 87 for 1000 miles.
  3. Sep 27, 2010 at 1:59 PM
    TheSchwartz
    Aaron
    Smithsburg, MD
    i might try that, thanks. have you noticed big improvements since switching?
  4. Sep 27, 2010 at 2:03 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Every single vehicle I have owned does the same thing, it's just how it works.
  5. Sep 27, 2010 at 2:04 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I use 85 in my 2007 and have the soot marks on my tail pipe but still get 18-20 mpg.
  6. Sep 27, 2010 at 2:16 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Pacific Northwest
    2018 OR DCSB 4x4
    Cleaning out the tailpipe with an SOS Pad will keep it looking new and wont scratch.. I feel that my wife's Audi that we ran 92 octane in got way dirtier than my Tacoma that I run 87 in... I have always been told that small amounts of soot in a tailpipe are fine.
  7. Sep 27, 2010 at 2:19 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    A SOS pad would scratch the TRD exhaust tip... ...
  8. Sep 27, 2010 at 2:19 PM
    SOSHeloPilot
    SOSHeloPilot My Favorite Song :)
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    I use 91 to 93 juice in mine all the time and have no problems like this.
  9. Sep 27, 2010 at 2:20 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Same thing on my exhaust tip, but I use 89-91 all the time.
    BTW, got any pics of the new truck?
  10. Sep 27, 2010 at 2:45 PM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    it's a very sad day when people clean the inside of there exhaust ?????
  11. Sep 27, 2010 at 2:48 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    No, it's called pride and attention to detail. Most hotrod/classic car owners do this every time the engine is turned over. Personally, I barely give the outside of it a sponge every 2-3 months I wash my truck... but it's also an off road vehicle.
  12. Sep 27, 2010 at 7:11 PM
    gcwaterski
    gcwaterski Well-Known Member
    I got tired of the soot and sawed my tail pipe off so that it dumps over the axle. My problem fixed. I like the way it looks much better.
  13. Sep 28, 2010 at 4:27 PM
    toyotatacomaTRD
    Pacific Northwest
    2018 OR DCSB 4x4
    Sounds crazy, but it actually doesn't.. I have done mine many times. When I had my 98 Tacoma, I had some chrome Smittybuilt nerf bars that would rust like crazy after the road salt in the winter.. It was the only thing that would remove the rust and not scratch. Kept them looking like new.
  14. Sep 28, 2010 at 6:16 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    If the soot bothers you try mothers mag and aluminum polish. Won't scratch your exhaust tips and is awesome stuff. I used to use it on my old G35 coupe. With the truck, I really don't care.
