11 fault codes at once
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wcarley, Mar 2, 2015.
  1. Mar 2, 2015 at 8:03 PM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    I have an 09 tacoma, started it 2 days ago and my dash lights up, brake light, abs light, check engine light. Speedometer doesnt work, gas guage wanders from full to half tank. Went to a local auto parts store and had em give me the codes. All wheel sensors, Speedo and positive battery cable. I work a lot and have only had the time to clean the positive cable and the leads that tie into my positive cable which did nothing to fix the problem. The Toyota dealership wants my money which I'm not giving up just yet. Has anyone seen this happen or have any good advice on how to fix this problem? Thanks, Wade
  2. Mar 2, 2015 at 8:07 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    gotta be something simple, check all your fuses.
  3. Mar 2, 2015 at 8:12 PM
    07regtacoman
    07regtacoman Well-Known Member
    Davis Ca
    07 Silver REG Cab
    Painted arm rests, 2011 front grille,Readylift for 5lug.
    Do a search,dont know which one but its a fuse
  4. Mar 2, 2015 at 8:18 PM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I would suggest alternator cuz that's how my truck reacted but I don't think the O'reily guys are *that* stupid to not know haha
  5. Mar 2, 2015 at 9:15 PM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    I will check the fuses and thank you for the information. I had a Ford diesel a few years ago and the tranny started acting strange, turned out it was low voltage due to the battery cable being bad. I thought it might be something like that with my Tacoma but I'll definitely check the fuses. I just had a remote start put in it and thought that might have something to do with it, they say it's not though. Thank you
  6. Mar 2, 2015 at 9:22 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Radio and fan still work? I've had intermittent issues with IGN1 and IGN2 fuses and they have me some of those issues.
  7. Mar 2, 2015 at 10:01 PM
    Partzguy
    Partzguy Well-Known Member
    Don
    North Texas
    2015 DCSB TRD Sport 4x4
    I worked in the automotive industry 40 years. And coincidences are few and far between. I'd bet money when your problem is finally figured out that it's related to the remote start installation.
  8. Mar 3, 2015 at 7:30 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Also I would check and clean my battery, frame and engine ground connections.
  9. Mar 3, 2015 at 7:35 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Definitely look at these first. Subarus for example commonly throw random codes when the battery starts going out. On my '08 I had speed sensor and steering angle sensor codes when that happened. Grounds and alternator could cause the same problems.
  10. Mar 3, 2015 at 7:42 AM
    BazzokaJoe
    BazzokaJoe Well-Known Member
    Olivier
    Canada,QC
    TRD OffRoad
    check you're wires could be a bad connection or somebody forgot to plug something good luck!
  11. Mar 3, 2015 at 8:47 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Could be a grounding issue somewhere.
  12. Mar 3, 2015 at 7:35 PM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    Radio and fan still work, speedo and gas guage are still not working correctly. I go on days off friday morning so I'll start going through things then. I'm planning on getting back in touch with the remote start people also. Thanks again for all the advice.
  13. Mar 4, 2015 at 12:47 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    There's one particular fuse -- I forget which one, but it's in the driver's knee box -- that does this when it blows. Seems like half the truck runs through it.
    1) Check your fuses
    2) Uninstall the remote starter (the slightest error in installation and you're FUBAR for getting things to work right again)
  14. Mar 6, 2015 at 3:28 PM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    So I disconnected the battery for 20 minutes to reset things and took it back to the auto parts store to have the codes read again. I'm down to 4 codes, all speed sensor according to the parts guy. I'm not sure if the spped sensor is the same as the wheel sensor, last time I had the codes read, their were 4 wheel sensors that came up? Ive checked both ABS fuses and they're fine as well as the rest of the fuses under the hood. So what's next?
  15. Mar 6, 2015 at 4:17 PM
    nucktaco
    nucktaco Well-Known Member
    Scott
    south surrey, bc
    08 Double Cab TRD Sport
    satoshi mod, sliders, tinted tails/3rd brake, 3" lift,
    not sure if it could be the probem but i had a mouse chew through my wiring a while back. caused the dash to light up. cost me like $300 at the dealer to track down the messed up wiring and get it repaired.
  16. Mar 6, 2015 at 4:43 PM
    Clearwater Bill
    Billy
    Largo Florida
    Seriously? What is the code for that? And where is the sensor?
    Piling on like several others...........
    Remote start (even if it's fuse related, the installer could have easily created the issue) LIFO (last in, first out)
    System grounds
    Battery on the way out
    Alternator on the way out. Don't know where the regulators are in these vehicles, in the alternator or in the ECU?
  17. Mar 8, 2015 at 11:26 AM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    The code is p0500
  18. Mar 8, 2015 at 11:52 AM
    wcarley
    wcarley [OP] Member
    Denver Colorado
    09 tacoma
    So I think I've found the problem. The previous owner put a 6" lift on it and didn't route the wires to both the left and right wheel sensor so they wouldn't rub on the CV boot. Crawled under the truck a few minutes ago and found both wires had been rubbing on the CV boot and rubbed it down to open wires which I assume have grounded out. No blown fuses but I'm guessing that's the problem, I'll keep you posted!
  19. Mar 8, 2015 at 12:32 PM
    dakotasyota
    Dakota
    Ellensburg, WA
    That Definitely could be it... Looking forward to results.
  20. Mar 8, 2015 at 2:40 PM
    Clearwater Bill
    Billy
    Largo Florida
    P0500 OBD-II Trouble Code
    Vehicle Speed Sensor Malfunction
    What does that mean?
    Basically this means that the vehicle's speed as read by the Vehicle Speed Sensor (VSS) is not working properly.
    I hope your problem is found, and this code would seem to support what you've found in the ABS sensors.
    My question was regarding the 'battery cable code'.
