11 mpg and power lose,
Discussion in 'Performance and Tuning' started by Novatd, May 5, 2013.
  1. May 5, 2013 at 2:38 PM
    Novatd
    Novatd [OP] Member
    Joshua
    so cal
    Tacoma 3.4, 4x4
    Lifted with 33 in tires. rest unknown
    Did a spark test that looked good then a compression test 1,3,5 all at 180 and 2,4,6 at 150. 3.4 v6
    the check engine light is on but have not got codes need to go have them checked.
    Any thoughts?
    my guesses are a burned up valve, bad head gasket. or bad cam timing.
    not sure what to do next.
  2. May 5, 2013 at 2:40 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Could be something like a clogged cat as well.
  3. May 7, 2013 at 5:48 PM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    A number of things test tps, o2, and coolant sensors first. If all are fine could be a bad injector hanging open. Clogged intake or exaught?
  4. May 8, 2013 at 10:27 PM
    Novatd
    Novatd [OP] Member
    Joshua
    so cal
    Tacoma 3.4, 4x4
    code P0171 bank 1 to lean
    and o2 sensor close loop?
    just got my scan tool still learning to use it
  5. May 8, 2013 at 10:35 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Compression looks OK.
    Consistency is the key, and you're within 20% on both banks.
    If you had a hosed valve or gasket, you'd have one cylinder lower than the others on the same bank.
    Wouldn't make sense for the 2,4,6 cam to have slipped a tooth... belt normally slips at the smaller sprocket on the crank, and I'd imagine you'd be off more than 30psi.
  6. May 9, 2013 at 6:13 AM
    colby8100
    Colby
    South carolin
    Ok so o2 is going into closed loop which is full enrichment because of a lean reading it sounds to me like a bad o2 or (maf?/map? Idk what they use) I'd start by cleaning the o2 and w/e sensor meters air and ohm test injectors (assuming fuel pressure is fine) if all the injectors are working re instal your clean sensors if it runs fine for a minute and then goes back to before its probably a clogged exaught and I would advise New o2s after clog is fixed. It wouldn't hurt to ohm test water temp, tps, and iat while your at it
  7. May 9, 2013 at 6:14 AM
    colby8100
    Colby
    South carolin
    A new fuel filter wouldn't hurt either
  8. May 9, 2013 at 12:43 PM
    Dano302
    Dano302 Member
    Any other codes? 02 sensors can go bad and cause similar problems. what are your mods?
  9. May 9, 2013 at 12:47 PM
    Dano302
    Dano302 Member
    And you guys have it backwards. Closed loop is normal operation, it stays in open loop when 02 sensor fault codes are present, but a 0170 should let it run in closed loop still unless there's companion codes to go along with it.
  10. May 9, 2013 at 2:08 PM
    colby8100
    Colby
    South carolin
    Sorry I had it backwards and it will also run open loop after exaught temps get over operating temperatures from it being rich
  11. May 9, 2013 at 2:15 PM
    colby8100
    Colby
    South carolin
    I'm thinking o2 or temp sensor its reading the o2 under closed loop so its compensating dumping too much fuel because of the lean bank reading
  12. May 9, 2013 at 2:16 PM
    colby8100
    Colby
    South carolin
    Open loop would've been full enrichment*
  13. May 9, 2013 at 2:19 PM
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    Don't know if it has been mentioned, but did you check the EGR valve?
  14. May 9, 2013 at 2:30 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Some one put a timing belt in it recently?
  15. May 9, 2013 at 5:26 PM
    Novatd
    Novatd [OP] Member
    Joshua
    so cal
    Tacoma 3.4, 4x4
    Thanks for all the input. Seems I need to do a full one over on the intake and exhaust system.
    I already have new o2 sensors just haven't put them in yet was waiting till I had a better idea what was going on.
    As for mods I just bought this truck and not sure what all was done. The P.O. said the engine was rebuilt 20,000 miles ago didnt say by who. Not sure how true that is.
    there was wiring to two switches from the cab to the engine housing but to what not sure. But it was removed.
    thinking it may have been a supercharger not sure never worked with those be for. ecu could be remapped as far as I know
    had a remote start that was shorting out the starter removed that and fixed the wiring.
    It's got a 4 inch lift I believe 33 inch tires.
    it's my Trojan horse u could say but bought it for something to do.
    I'll take a bunch of pics and post.
    Love the feed back I'll keep posting as thing progress.
  16. May 10, 2013 at 4:12 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You should have a look at the cam timing. One cam is the even side the other the odd side your compression is lower on the odd side but even. If the cam timing is off it will lower the compression you can have one cam in time and the other one off this may explain why the compression is better on the even side. It can cause your lack of power and poor mileage and not set a code. O2 sensors will set an emission code if you even look at them wrong.
  17. May 10, 2013 at 12:02 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Okay... Had we known this up front, some answers may have been different.
    We were answering under the assumption that the truck used to run properly and it got worse without you making any changes to the engine.
    Was it running properly when you bought it and it suddenly dropped, or has it always been like this?
    I'd be inclined to agree that one cam may be out of time. Installing the timing belt is easy and it is a bonehead move to get the cams out of time, but if the "assembler" is not paying attention, it happens.
  18. May 10, 2013 at 1:45 PM
    colby8100
    Colby
    South carolin
    That actually makes a lot of sense for the different compressions
  19. May 10, 2013 at 7:42 PM
    Novatd
    Novatd [OP] Member
    Joshua
    so cal
    Tacoma 3.4, 4x4
    That's what I was leaning towards myself. And bone head moves seem to be a theme with this truck. The transfer case shifter was installed in the 4low position when it was actually in 2hi so it seemed as though it was a ceased transfer case. When they put a new cluch in I'm assuming. Glad I figured that one out. Don't get me started on the halfassed wiring.
    looks like I got a long weekend ahead of me.
    sorry should have pointed out earlier that I just got it. And no it ran this way when I bought it.
    thanks again.
  20. Jun 10, 2013 at 4:41 PM
    Novatd
    Novatd [OP] Member
    Joshua
    so cal
    Tacoma 3.4, 4x4
    so here is the update
    replaced both O2 sensors and i had 2 missing bolts on the exhaust one for the cat and one for the up stream sensor replaced the gaskets for the cat now getting 13-14 mpg
    after this all my engine codes have been fixed
    now for the thing that is still got me confused so my compression test was 1,3,5 all at 180 and 2,4,6 at 150
    so did a leak down test all cylinders "except 2" are between 10-15% witch is not bad as far as i Know.
    OK so 2 is close to 100% loss witch makes no scene if im getting 150 compression right. now i did this cylinder five times with redoing TDC every time and it sounds like a lot of air is coming back out of the spark plug hole but it is coming out of the intake as well witch is intake value problems. but 150 compression no misfires im confused
    when i was running lean i would get a random cylinder 2 misfire though.
    any thoughts?
    i did check the timing belt and all markers and notches lined up the 2 on the cams and the one on the crank shaft. this means its fine right?
    updated i did check the cyl 2 compression again and dry is 90 and 140 to 150 wet so i know head rings are going.
