11 quarts of oil mistake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dano 5, Jun 3, 2011.
  1. Jun 3, 2011 at 1:41 PM
    dano 5
    dano 5 [OP] New Member
    Tempe,AZ
    05 prerunner dc sport
    I am another one of those guys that drained the tranny on the first oil change. I only made the problem worse because it was dark and I am color blind.....so I filled it bak up w/oil. yah just topped it off with stupid and ignorence. Then not realizing that I then had no trans fluid 11 quarts of oil I start my truck, warmed it up, revved it up pretty good, and tryed to take it for a "cuise". It didn't ride very nice so I pulled it back into the driveway, drained all 11 quarts, and NOW I have 5.5 quarts oil and new trans fluid(thanks to the transdrain/refill post. My question is how much damage could I have done? I have no leaks but engine seams a pinch ruff(probibly in my head but still). When everybody stops laughing, I know it was dumb but any help or advice to make me trust my truck again would be cool. ps I have only owned it 45 day and just made my first payment. ouch!!!!:confused:
  2. Jun 3, 2011 at 1:45 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    well you definatly hurt the engine a little probably. how far did you drive it?
  3. Jun 3, 2011 at 1:47 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
  4. Jun 3, 2011 at 1:48 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    A double wammy, no trans fluid and twice as much oil as needed. How far of a drive did you take? These are some tough little trucks.
  5. Jun 3, 2011 at 1:50 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    I would be more worried about the lack of transmission fluid. Transmissions are not known to like any travel sans fluid.
  6. Jun 3, 2011 at 1:51 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    K so just to make sure I understand, you now have everything back to as it should be correct? oil in engine, trans fluid in tranny??? also, if you put oil into your transmission, you should probably get a transmission flush.
    Describe the new feeling the engines giving you,
  7. Jun 3, 2011 at 1:57 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    he didn't put oil where the tranny fluid should be, he just doubled up the oil cause he never took any out.
  8. Jun 3, 2011 at 1:59 PM
    97yota4wd
    Eric
    Mesa, AZ
    so to be clear he ran the truck with no transmission fluid, and he had 11 quarts of oil.
    so op how far did you drive?
  9. Jun 3, 2011 at 2:05 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    if i were u, i'd drain out ur new trans fluid and look for any metal shavings in it. u probably jacked up ur trans worse than the engine.
  10. Jun 3, 2011 at 2:08 PM
    YFZ_TRD
    YFZ_TRD 4Runner Pilot
    Lee
    Beaverton, OR
    2014 4Runner SR5
    This^^
    I assume you have an automatic since you keep calling it transmission fluid (manuals tend to just be called gear oil). But yeah, I would get your transmission checked out. I'm surprised it even shifted without fluid since a lot of the function of an automatic depends on the presence of fluid :eek:
    Running with 11 quarts, your crank was probably spinning in a bath of oil along with your rod connectors. Hopefully nothing was bent.
  11. Jun 3, 2011 at 2:16 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    How many miles does your taco have? You can top off your fluids correctly and take it to toyota and act like it started acting up for no reason. We can call it "WTF tsb."
    mods sticky this up top please. :cool:
  12. Jun 3, 2011 at 2:42 PM
    dano 5
    Tempe,AZ
    I refilled my trans w/ trans fluid and refilled my oil w/ 5.5 quarts of oil. I only drove about 1000 feet at less than 5 mph. It idles fine and in park in revs smooth. I drove itabout 18 miles to work today, it shifted fine and I got it up to 75 -80 mph .At lunch I noticed a slight diesiling noise as I accelerated from 40 mph to 50. It just sounds lick it is dogging down slighty. It is probibly in my head but the truck is 05 prerunner w/50k miles but it is still new to me.
  13. Jun 3, 2011 at 2:44 PM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    Yay! Advising the OP commit fraud.
    :bananadead:
  14. Jun 3, 2011 at 2:45 PM
    KEG'sTACO
    KEG'sTACO FJ Cruiser
    Kurt
    Auburn, AL
    '08 FJ Cruiser
    Leveled, 33" BFG A/Ts, Demello Offroad front flat-top bumper, Demello Offroad rear 3-piece bumper, 17" Liquid Metal Gatlins, Pioneer audio upgrade, custom mounted 10" subwoofer, offroad interior
  15. Jun 3, 2011 at 2:48 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Do tell
  16. Jun 3, 2011 at 2:49 PM
    dano 5
    Tempe,AZ
    sorry ...when I had no trans fluid and double oil I drove only 1000 ft at around 5 mph then fixed everything and drove to work today at the faster speeds described
  17. Jun 3, 2011 at 2:54 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I remember hearing about that, never saw the video though.... hahaha dumb ass
  18. Jun 3, 2011 at 3:12 PM
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    Honestly, I wouldn't be too worked up. As bad as it seems to liquid lock the engine, you would need enough oil in it to seep past the rings on the lowest piston, not very likely.
    It most likely made a big foamy frothy whirring sound.
    As for the tranny, it's all bearings and wet clutches, you really didn't work it hard so it should be fine. For the most part these trucks with automatics shift so soft, you may have helped it shift better.
    Drive it and enjoy it. You have a warranty, not saying commit fraud, but if it lasts for a couple years and acts up, very unlikely it was caused by this. You would do best to forget it ever happened, but don't try it again.
    PK
  19. Jun 3, 2011 at 3:19 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    PLEASE! :annoyed:
    Just step back from the motor if you do not know what your doing...I can not believe anyone with minimal mechanical abilities would drain the tranny instead of the motor oil. :der:
    OP - your probably lucky you did not drive far, as suggested you should flush the tranny and refill. If everything is good to go from here, just check daily that no seals, gaskets, etc. were blown on the motor during the ordeal. I bet you will be ok...:p
  20. Jun 3, 2011 at 3:26 PM
    YFZ_TRD
    Lee
    Beaverton, OR
    2014 4Runner SR5
    I like to touch my mini-pan :spy:
