110 volt bed plug
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ggparts, Aug 7, 2008.
  1. Feb 7, 2009 at 7:32 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Exactly... So why the fuck did Toyota make it drop to the lower power setting when the truck is moving and the engine running instead of the other way around? :rolleyes:
  2. Feb 7, 2009 at 7:34 AM
    RoyB
    RoyB Well-Known Member
    Chicago burbs
    '09 TRD DC Sport
    I think mine is set to 100 watts when the engine is not running and 400 when running in park.
  3. Feb 7, 2009 at 7:49 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Yeah, that's how it works, but as soon as you shift out of park (or push the clutch in a manual) it drops to 100W. So if you have a cooler or something in the bed that draws more than 100W if won't work while you're driving. I'm thinking like a cooler or warmer to maintain food or drink on a long trip. It would be nice to do that, but sorry it won't work like that from the factory. Kinda stupid IMO. I mean, it's not big enough to run most useful tools while parked so why not run a larger appliance while driving? :rolleyes: Unless it's a "safety" feature for idiots that would make margaritas while driving.... :laugh:
    Edit:
    Mine will do 400W with the engine off and key turned to ON so it's not a battery conserving thing.
  4. Feb 7, 2009 at 7:54 AM
    Joe B
    Joe B Well-Known Member
    All in all the bed inverter is a pretty useless.
    Sounds like a nice option until you know how it works.
  5. Feb 7, 2009 at 8:11 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The only useful thing I've found for the inverter is for hooking up some lights when I am launching or messing with the boat in the dark and I don't want to waste batteries in my flashlights. One of the things I thought of when I saw it was for a compressor but that was nixed after I plugged it in and it didn't turn on.
  6. Oct 15, 2016 at 10:53 AM
    TXOverland
    TXOverland Well-Known Member
    Clayton
    San Angelo, TX
    Does anyone know if I could plug a power strip into it? I'm going for a camper shell camping rig and I'm trying to figure how to power some stuff in the bed.
  7. Oct 15, 2016 at 11:11 AM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    I would think a power strip would be fine as long as your combined load is less then the 400w
  8. Oct 15, 2016 at 11:19 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    The power strip won't make a difference. What you plug into the power strip will. Every item will have a label stating what it's power usage is, usually in watts, add those up and see if they exceed the output of the outlet. 400 watts isn't much, 100w is very little.
  9. Oct 15, 2016 at 11:46 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  10. Oct 15, 2016 at 12:31 PM
    TXOverland
    Clayton
    San Angelo, TX
    Dang, maybe I just need to rig up a solar panel set up and extra battery to run my stuff
