12’ Tacoma 4D I am having a weird engine noise almost above the wheel well in the engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CharlestonScTacoma, Dec 21, 2020.
  1. Dec 21, 2020 at 4:28 PM
    CharlestonScTacoma
    CharlestonScTacoma [OP] Active Member
    Will
    2012 Black Toyota Tacoma, 285/65/16 BF GOODRICH KO ALL TERIANS 3" Inch Spacers In Front.
    285/65/16 BF GOODRICH KO ALL TERIANS 3" Inch Spacers In Front. All LED interior and exterior. Many more to come.
    So like I said in the front wheel well area of the engine, I’m having this noise in my engine and it’s in the front right where the wheel well Is but it’s only happening when I give it gas the engine or when I put it in gear and going to drive and drive away makes this noise when I give the gas but when it’s just idling it doesn’t make the noise but as soon as I tap the gas it makes the noise. I know it’s got to be some thing in the engine I live in this place called Charleston South Carolina and there’s a lot of flooding and I have hit a lot of puddles but I am wondering what y’all think about some thing maybe getting dislodged and what would make that noise it’s like a clicking sounds like a broken fan or some thing I’m not sure let me know if y’all know anything I really appreciate it thank you so much! Here’s an updated picture also! For new BF Goodrich KO2 all-terrain’s
  2. Dec 21, 2020 at 4:37 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The air pipe for the intake to the air box run in there.
    Have you looked there?
  3. Dec 21, 2020 at 4:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Video clip with sound would help alot in determining what it is.
    TnShooter likes this.
  4. Dec 21, 2020 at 4:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Is the vacuum switching solenoid on that side?
  5. Dec 21, 2020 at 4:42 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    No, it's on the left (drivers) side
  6. Dec 21, 2020 at 4:42 PM
    TnShooter
    Deogee
    STOCK
    Maybe the SAIS........let’s hope not:fingerscrossed:
  7. Dec 21, 2020 at 5:24 PM
    CharlestonScTacoma
    Will
    It’s on the passenger side front right
  8. Dec 21, 2020 at 5:24 PM
    CharlestonScTacoma
    Will
    I will take video if needed
  9. Dec 22, 2020 at 12:31 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Check your idle pulleys and tensioner, as well as alternator and AC compressor see if the pulleys spin freely. Take the belt off to do this and check that belt to see if its glazed as in one of above freezing up. If only when hitting the gas fairly hard check the tensioner tension as its spring loaded and can wear out and get looser and belt slips on hard throttle.
    Steves104x4 likes this.
  10. Dec 22, 2020 at 12:51 AM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    It's your air intake pipe insulation wore off where pipe goes thru pass fender
  11. Dec 22, 2020 at 1:13 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Heat shield?
  12. Dec 22, 2020 at 2:49 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I bet parking one with a 12' bed is a PITA. You have a '12. :thumbsup:
    Island Cruiser likes this.
  13. Dec 23, 2020 at 12:58 AM
    CharlestonScTacoma
    Will
    What is that?
  14. Dec 23, 2020 at 6:57 AM
    CharlestonScTacoma
    Will
    It was the heat shield! Poor design haha I removed it because it’s not even needed really!
  15. Dec 23, 2020 at 6:57 AM
    CharlestonScTacoma
    Will
    Thanks everyone !
