12-14 mpg!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06Bluez, Oct 30, 2008.
  1. Oct 30, 2008 at 3:48 PM
    06Bluez
    06Bluez [OP] Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    past few times I have filled up and checked my MPG's i have been ranging between 12 and 14 MPG's. I have 33" all terrains, 2.5" lift, AFE CAI, Doug Thorley Y-pipe, and Magnaflow cat back. I would say my driving is 65% highway and 35% City. I wouldn't say i drive aggressivley but rarely i will get on it to make a pass. I use Premium Chevoran Gasoline. Shouldn't I be getting better gas mileage than this? Anyone have same problem?
  2. Oct 30, 2008 at 3:50 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    12-14:eek: I have an extra 200 pounds,3'' lif and 265 coopers and I am around 18+, Thats pretty crazy.
  3. Oct 30, 2008 at 3:51 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...Even with whatever you've added...That seems excessive.
  4. Oct 30, 2008 at 3:54 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    I thought the CAI they Y-pipe and Magnaflow was actually supposed to increase MPG's.
  5. Oct 30, 2008 at 3:56 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    are u taking into consideration the tire size causing tht ODO to be off, or are u going straight by it?
  6. Oct 30, 2008 at 3:58 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    No, that must be my answer!! So how do I calculate it accuratley with my 33's?
  7. Oct 30, 2008 at 4:05 PM
    jhodge83
    SC
    17 XLT Sport
    the best way is to go to a tire calculator and compare the stock size to the new size....then add/decrease that percentage to the total mileage. i think thats the easiest way, but some of the brainiacs around here have their exact methods...lol
  8. Oct 30, 2008 at 4:07 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    TcBob made a tire size calculator (Under the Mods & Tutorials pulldown). http://www.tacomaworld.com/forum/tirecalc.php
    That's some of it. You've got about a 7% speedo/odo error (indicates 65 when you're really going 69).
    240 indicated miles +7%= 257 actual miles
    So you're probably getting close to 13-15mpg. Bigger tires will reduce your mileage some. Plus, if you keep it close to 60mph indicated, you'd be going the speed limit. Measure it by your RPM. Keep the RPMs under 2000.
  9. Oct 30, 2008 at 4:11 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Looks like that would be a fun little equation.
  10. Oct 30, 2008 at 4:15 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Not sure what your problem is but my mileage is starting to fall lately maybe they have changed the fuel around here. I have been getting 15 and 16 way to often.
  11. Oct 30, 2008 at 4:18 PM
    jhodge83
    SC
    17 XLT Sport
    true too....less mileage on the 90/10 mix of fuel and if they've already starting putting out the winter mix stuff
  12. Oct 30, 2008 at 4:32 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    I just check mine this week, I posted before in regards to speed-o error/being off and my lift. I am getting 19 mpg with the last tank, with me heading south hunting and gas coming down I will be filling up again soon.
    I have noticed a little more pinging than normal, must be that winter mix thing that they are talking about. I am also using Shell, I don't know if that matters, but my father swears on certain stations gas.
  13. Oct 30, 2008 at 5:20 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X2! This is how I calculate my mpg. :)
  14. Oct 30, 2008 at 5:25 PM
    jhodge83
    SC
    17 XLT Sport
    i go by my gps. it tracks the miles that i actually go on there w/ no connection to the vehicle and its dead on mileage w/ mileage signs on the interstates
  15. Oct 30, 2008 at 6:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I always make the correction. Seems my mileage has been droping and I have been driving cautiously. However I ran one tank hard as hell, made about the same mileage as when I baby it. The following tank was cautious and still no good. I however don't have all the mods the OP does, just the lift and tires.
  16. Oct 30, 2008 at 6:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I used to use my GPS, and I do when testing, but for the most part, I just calculate it out.
  17. Oct 30, 2008 at 6:44 PM
    20taco07
    20taco07 Well-Known Member
    sacramento
    2007 toyota tacoma sr5 trd sport 4x4
    i get 16mpg mixed driving, with my 33's and 3" lift
  18. Oct 30, 2008 at 6:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    yeah but it should be better. During the hurricanes I took a 5hr trip, truck was loaded and we drove 70+ mph up hills. I made 21.7 mpg. Now home driving on flat ground keeping to 65mph unloaded I make 16.4 or 16.8 my latest trip. In town I make low 15's. We should be getting better than that even with lift and tires. Especially the OP with his mods.
  19. Oct 30, 2008 at 8:37 PM
    Smurfio18
    Smurfio18 Well-Known Member
    Northridge
    06 Tacoma TRD PreRunner
    I keep it Stock but Clean!
    Sounds like you did the right mods to increase gas efficiency but I think all you might need is a tune in order to get better gas mileage.
  20. Oct 30, 2008 at 8:50 PM
    SoCalPrerunner
    SoCalPrerunner Well-Known Member
    06 DC LB w/ Front & Rear LT
    Front & Rear LT
    sound about right to me...i get 15 if i'm lucky
