12 - 14 MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roadwarrior67, Dec 1, 2014.
  1. Dec 1, 2014 at 2:52 PM
    #41
    T4RFTMFW
    T4RFTMFW Well-Known Member
    75 lbs?! DAMN
  2. Dec 1, 2014 at 3:06 PM
    #42
    jandrews
    '09 FourDubDee TRD OR
    My trail graps are 78# per tire according to Nitto's website. This is unmounted.
    Nitto's tires are very nice and very strong, but also very goddam heavy. The same size KM2s, for reference, are 62lb per tire. We'll see how I like the Nittos, but being that goddam heavy this may be the only set.
  3. Dec 1, 2014 at 3:58 PM
    #43
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    You know, I had a 2008 Outback with the 3.0 H6 in it and my best ever mileage was driving through upper Maine at 80-85. Got almost 28 MPG. Generally it would barely touch 24 on the highway when going 65-70.
  4. Dec 1, 2014 at 4:00 PM
    #44
    T4RFTMFW
    Hm..
    He has the smaller engine prone to head gasket diets. Interesting. He thinks it's the CVT transmission, but seems a little counterintuitive.
  5. Dec 1, 2014 at 4:45 PM
    #45
    Arkansas30
    Arkansas30 Well-Known Member
    Conroe, Tx
    2014 Titan Pro4x
    My truck is all stock in baja form. I have got around 21 hwy. Easy on the gas 75mph and lower. I try to take it as easy as I can taking off. I have seen 22 once.
  6. Dec 1, 2014 at 5:02 PM
    #46
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    my 6 speed DCSB with 32's gets 12-14 mpg lately. It is now up for sale. BS gas mileage.
  7. Dec 1, 2014 at 6:07 PM
    #47
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    The manual is definitely no good for gas mileage. I jumped up about 4 mpgs when I went to auto.
  8. Dec 1, 2014 at 6:20 PM
    #48
    roadwarrior67
    roadwarrior67 [OP] Member
    birmingham,al
    2013 Prerunner TRD Sport
    2" LIFT, K&N FILTER.
    some of the help makes sense, i will do some research on some of these tips and let you know how it goes. definitely some nice looking trucks here.
  9. Dec 1, 2014 at 6:27 PM
    #49
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    ^^^ All these factor in to the mileage for the truck.
    1. crappy winter blend with ethanol
    2. tire weight and rolling resistance
    3. auto> manual. Proven by many
    4. Driver's driving habit
  10. Dec 2, 2014 at 8:18 PM
    #50
    Pigeon
    Pigeon Well-Known Member
    PJ
    Eria, PA
    05 Double Cab Long Bed
    I'd dump that pig, it drives me crazy when people says who cares what mpg you get its a truck. The sole reason I drive a Tacoma over a real truck is mpg. I use mine for work it sags in the back from the weight, I go through wheel bearings, brakes rotors and calipers alot , its really a 4runner with a bed it should get good gas. Gas is my biggest expense. I'm very happy with my 17mpg mixed with a 24' ladder, contactors cap, and a heavy foot. Although it changes drastically with the winter gas I go from 300+ miles a tank to barely making 250. I keep my tires at 50psi
  11. Dec 2, 2014 at 8:37 PM
    #51
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    I get great mpg with cruise control and a stick. It's the automatic that seems to stink it up by over reacting and downshifting 1-2 gears then overshooting the set speed. Not very refined.
    6-speed is only lower mpg than automatic on the V6 because the overdrive ratio sucks. Change the OD to the same as the automatic and the stick would beat the auto.
  12. Dec 2, 2014 at 9:52 PM
    #52
    Marcoc
    Marcoc Well-Known Member
    Connecticut
    2017 Tacoma TRD Off-Road LB
    2017 Tacoma TRD OR LB white w/tech package
    That sounds a bit exaggerated, nothing personal. I'm averaging 14.5 mpg according to Fuelly.com. Granted its the winter blend up here in the NE, I'm lifted, LT tires etc. But in the summer I can see 16 or 17 best. No where near 22!!! My father has a 2014 TRD OR DC bone stock and gets 18 or so. Its a lifted truck OP gas isn't its strong suit.
  13. Dec 3, 2014 at 4:06 AM
    #53
    33yrsoftoys
    33yrsoftoys Over 40yrs now
    joel
    mid Michigan
    2021 dcsb off road 6 speed manual
    Bilstein 6112's 5th clip 1/4" spacer driver's side. Icon tubular UCA's with Delta joint, wheelers superbumps, ECGS bushing. Allpro standard leaf packs, 5160's, U bolt flip kit with wheelers super bump's, extended stainless steel brake lines, carrier bearing drop. Icon rebounds 17" with Nitto terra grappler G2's 285/70/17's.
    I think username's on to something. I think it's got something to do with the ecu and air/fuel ratios.
    I checked my mpg yesterday. 94.5 mi, all highway. 17.3 mpg. Filled up there, drove back the same road to the same station I filled up in the first place and filled up again. 19.4 mpg! Go figure? Sunny day, light winds, pancake flat terrain, cruise control set at 73mph. The only difference was temp. The trip down, 25-31°. The trip back, 32-36°. Makes me wonder if the ecu does an air/fuel adjustment at 32°? Any ideas?
  14. Dec 3, 2014 at 5:30 AM
    #54
    33yrsoftoys
    joel
    mid Michigan
    Worthywads is right. The final drive ratio on the 6 speed is .85/1. The auto is .72/1. The 6 speed doesn't get to 1/1 until 5th gear. The 6 speed 0-60 times will be better though.:)
  15. Dec 3, 2014 at 5:37 AM
    #55
    mattvivsound
    mattvivsound Well-Known Member
    Southern MD
    '01 Tacoma TRD, 4x4, V6
    On a stock motor, that won't do anything helpful and I am pretty sure that there is a set of 02 sensors after the last set of cats.
  16. Dec 3, 2014 at 5:51 AM
    #56
    Frobozz
    Frobozz Well-Known Member
    North of Ordinary
    15 TRD/OR Access Blue Ribbon Metallic
    Tonneau, Canoe Rack
    Good luck. I agree your reported mpg would be unacceptable to me. May as well own a big ole F250.
  17. Dec 3, 2014 at 6:17 AM
    #57
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Self inflicted wounds.
