'12-'15 headlight mod
Discussion in 'Lighting' started by Sailorboy92, Mar 14, 2015.
  1. Mar 14, 2015 at 11:10 AM
    Sailorboy92
    Sailorboy92 [OP] Member
    Michael
    Michigan
    '15 Tacoma TRD Sport DBL Cab
    none so far
  2. Mar 14, 2015 at 11:27 AM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
  3. Mar 14, 2015 at 9:40 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    $600 is way too much for that garbage IMO.
    I think they are butt ugly too. :puke:
  4. Mar 14, 2015 at 9:43 PM
    THE CALICO
    Colton
    Nashville
    X10
  5. Mar 15, 2015 at 12:12 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '09 R1, '03 cbr954rr, '03 rc51
    X2. And it'd probably be cheaper actually. Even cheaper if you can manage the project yourself.. Really not that hard.. And yes, you'll have way better output. As well as the satisfaction of a successful diy. And the praise you'll receive from us;)
    Also, being a '13, I imagine your headlights you have now aren't that bad of shape? Can probly use those and save yourself the cost of new housings. If anything is needed, restore the lenses if they're slightly hazed. Then wrap them in clear uv protectant film to delay further hazing. Or maybe clear coat them. But most just get new housings.
    If you really insist on wanting those lights, I would wait until the price drops. Because they most likely will. Then when you get them, some preventative maintenance will be needed. Probly reseal them with silicone. Or even perhaps retro some minis from Trs in them and reseal with butyl.
  6. Mar 15, 2015 at 1:06 AM
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    I'm with everyone else. I'd find a member on here like ambiguous or pete from insight retrofits to build you a set or take on the project yourself. There are lots of write ups and it would be cheaper.
    I hear that some people like those lights, but they tend to leak and the performance for that price is not too great.
  7. Mar 15, 2015 at 1:13 AM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
  8. Mar 15, 2015 at 6:10 PM
    Sailorboy92
    Michael
    Michigan
    none so far
    The reason as to why I want to up grade the headlights is to upgrade the look ...... there is nothing wrong with the stock headlights.
    I know that it is a bit pricey and have not bought it yet. Just saw them and thought of adding it to my mod list. I have done a Google search on the mod headlights and saw the the prices range from $459.00 to $599.00. If I were to buy them it will be DIY project .
  9. Mar 16, 2015 at 1:36 AM
    Twinkie0311
    Hillsboro, Oregon
    If you are going to do a DIY check out the ongoing group buy from The retrofit source if you do Mini H2 the price for parts isn't bad and if you do it to your oem lights without buying a second set of headlights that will cut cost down as well.
  10. Mar 16, 2015 at 3:31 AM
    BronsDaGreat
    BronsDaGreat Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    Those headlights are hideous!! Dont do it man.. way better options out there.. You want to make them look good without spending alot of cash do the BHLM..
  11. Mar 16, 2015 at 3:48 AM
    Large
    Large Red
    I've seen a 2nd gen with those blacked out ones, doesn't look too bad IMO.
