12-15 iPad Mini Bezel with Radio Access
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Guat, Jan 10, 2017.
  1. Jan 10, 2017 at 2:25 PM
    Guat
    Guat [OP] Well-Known Member
    The Big NC
    I purchased this iPad Mini bezel back in July and never came around to installing it. With plans to purchase a newer truck this guy will have to make someone else happy. Looking for $300, you pay shipping and the 3% PayPal fee. New Lighting Cable (seen in pictures) in place and you will either have to reuse the clips on your current radio or purchase them. The opening in the center gives you access to a Single Din when the iPad is removed, convenient for those whose steering wheel lack radio controls. Don't hesitate to ask any questions here or through PM, thanks and enjoy!
    *Item located in North Carolina Triangle Area and able to meet within a 30 mile radius
    * Image added 22Jan17, 4th Gen iPad Mini
  2. Jan 10, 2017 at 2:31 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    If only I didn't hate apple.... That's a nice bezel none the less. GLWS!
    taczilla and highdefdinardo like this.
  3. Jan 10, 2017 at 2:35 PM
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    Damn it, why do these always come up AFTER I spend money fml
    ...pm inbound lol
    thebaker likes this.
  4. Jan 10, 2017 at 4:21 PM
    DistortedAxis
    DistortedAxis Well-Known Member
    Toronto
    Desert Sand Mica, 2006, V6, 6SPD Manual, SR5, DCSB, 4X4
    STOCK
  5. Jan 17, 2017 at 2:40 PM
    Guat
    The Big NC
    Taco Tuesday Bump
  6. Jan 22, 2017 at 5:04 AM
    oats
    oats Active Member
    2014 TRD OR
    Who manufactures this trim piece and does it work with all iPad minis?
  7. Jan 22, 2017 at 11:54 AM
    Guat
    The Big NC
    The bezel was made by Metra and the kit it self was purchased online shipped somewhere from southern California. I was told this works with all generations of iPad Minis but I can attest that it works with a 4th gen. I can provided you with an image if you like.
    * Added image with iPad Mini in first post
  8. Jan 22, 2017 at 4:33 PM
    Greattaytay
    Greattaytay HoosierTaco
    Taylor
    Indianapolis
    2004 DCSB Lunar Mist 4x4 TRD Limited
    This won't fit in an 05?
  9. Jan 22, 2017 at 5:36 PM
    Guat
    The Big NC
    05-15 bezel are interchangeable, the aesthetic lines are what changed in the 12-15 models due to the radio from my understand. Some 05-11 owners "upgrade" their surrounding radio bezel for that refresh look. I've attached an example below to give you a visual of what the out come would look like, hopefully this helps,
    This sounding bezel comes from an 07 which is the same as your 05.
  10. Jan 26, 2017 at 1:16 PM
    whitetaco97
    whitetaco97 Well-Known Member
    Tyger
    2017 White TRD sport
    Does this replace the radio?
  11. Jan 28, 2017 at 6:06 PM
    Guat
    The Big NC
    Yes and no. Some opt to running a mini without a car radio others do, it's all preference on how you want your set up.
  12. Jan 28, 2017 at 8:42 PM
    DistortedAxis
    Toronto
    STOCK
    How is the iPad held in? does this use magnets?
  13. Jan 29, 2017 at 6:38 PM
    Guat
    The Big NC
    With Honor & Courage...
    Lol, the iPad Mini slips in and held by both the Lighting Cable and the side lip not allowing it to pop out. To eject, slide to the right and push anywhere on that corner for removal. No magnets needed.
  14. Feb 10, 2017 at 10:49 AM
    Guat
    The Big NC
    Friday BUMP :ohsnap:
  15. Feb 10, 2017 at 5:14 PM
    Guat
    The Big NC
    Sold, thank you TW.
