12-15 year-old oil filters. Still good?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SWPA Tacoma, Aug 29, 2025.
  1. Aug 29, 2025 at 1:02 PM
    SWPA Tacoma
    SWPA Tacoma [OP] Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    Cleaning up the garage today and found a couple of filters that I bought long ago when I could physically change my own oil. I'm guessing they were purchased around 2008-2010. Boxes were in good shape and the plastic seals were both intact. They look in brand new condition....but I am concerned that the filtering medium may be breaking down from age. Would you still use these if it were your 2006 truck?
    Mickey SGV, steelcity2 and hinmo24t like this.
  2. Aug 29, 2025 at 1:31 PM
    TOYOTA 09
    TOYOTA 09 Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
  3. Aug 29, 2025 at 1:38 PM
    eherlihy
    eherlihy 2009 Access Cab TRD Off Road
    Florida or Massachusetts
    2009 TRD Offroad Access Cab in Silver Streak Mica
    Provided that they aren't Fram filters, I would use 'em.
    SWPA Tacoma[OP] likes this.
  4. Aug 29, 2025 at 2:11 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    There would be no reason for Fram filters to be any better/worse than any other filter of that same age. In fact, if the filter was an original Fram Ultra then it would actually be better than most filters due to it having synthetic media with superior micron rating.
  5. Aug 29, 2025 at 2:38 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've been using Fram for decades. It seems that some think they're comparable to a rolled up tube sock when it comes to filtering. Lol, you do you.
    Yes, I'd use them.
  6. Aug 29, 2025 at 2:54 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Yes, I would use them without hesitation.
    SWPA Tacoma[OP] and O'DubhGhaill like this.
  7. Aug 29, 2025 at 3:01 PM
    Bishop84
    Bishop84 Well-Known Member
    The only issue with older rubber is it shrinks, it 100% needs to be lubed before you use it.
  8. Aug 29, 2025 at 4:28 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    I wouldn't. The adhesive holding the paper media pleats together may have broken down. The paper may disintegrate after the first heat cycle. Hell, it may have been designed this way, for the media to be biodegradable.
  9. Aug 29, 2025 at 5:40 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    I'd contact the filter manufacturer engineering dept. and ask their advice.
    It may be fine, or it may destroy your engine.
    SWPA Tacoma[OP] and 23MGM like this.
  10. Aug 29, 2025 at 6:11 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    we're talking about oil filters right? :crazy:
    I buy oem filters by the case of 10 and change the oil/filter once a year... last filter in case is at least 10 years old by then... never had an issue. I always lube the rubber gasket.
  11. Aug 29, 2025 at 6:18 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    Would use them provided they were in original box or wrap and not water damaged.
    Have used filters older than that on vehicles, tractors, ATVs, etc. with never an issue.
  12. Aug 29, 2025 at 6:35 PM
    MGMDesertTaco
    Climate plays a role in shelf life. New oil filters don't cost that much.
  13. Aug 29, 2025 at 6:54 PM
    SWPA Tacoma
    Stevo
    Thank you all for your time in posting. Excellent points made both ways. You guys rock!
  14. Aug 29, 2025 at 7:43 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I personally would not use them, yes they’re probably good but is it worth the chance, not to me, not for $15
    Grey 2015 and SWPA Tacoma[OP] like this.
  15. Aug 29, 2025 at 7:44 PM
    GilbertOz
    GilbertOz Driver
    CA
    They're probably fine 25 years later
    if oil filters in general had any tendency to fail in long shelf life storage (>15 years) we (the internet) would have probably heard about it by now
  16. Aug 29, 2025 at 7:52 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'll take them even if they are Frame units.
    Many Commercial lawn mowers use the same filter. If they are #3614, they fit lots of small engines.
  17. Aug 29, 2025 at 7:59 PM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    You could use them, but then change your oil change interval from 10k to 5k or 5k to 3k and then send a sample off to Blackstone, and then compare that against a few filter then depending on what brand of oil you use and viscosity report back. Keep us posted.
  18. Aug 30, 2025 at 7:02 AM
    SWPA Tacoma
    Stevo
    Only put 3-4,000 on my truck each year. My truck is my weekend hunting and fishing vehicle. I usually have my oil change done every fall with my state inspection. I'm old, so I don't have the stomach to go 10,000 between oil changes.
  19. Aug 30, 2025 at 7:06 AM
    lineman4tacos
    lineman4tacos Well-Known Member
    Placer County, CA
    2000 Regular Cab (3RZ / W59)
    Yes, manual everything...even mirrors...
    Good question - but for such a cheap (but critical component), doesn’t make logical sense to risk it if material breakdown has occurred.
    People also say the FUEL filter is a lifetime part and not to bother with it yet the pic below is after 140k miles on my 3rz that was a Reno truck…..
    Point being: always good to error on the side of caution out of love for these trucks.
