12 4wd 4 cyl gas mileage vs 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ktm125, Sep 14, 2011.
  1. Sep 14, 2011 at 9:34 AM
    ktm125
    ktm125 [OP] Member
    Greg
    Chattanooga
    '10 4 cyl Manual Access SR5
    the 2wd is rated 19/25 and the 4wd is rated 19/21 (automatic for both)
    anyway to get the 19/25 on the 4wd such as running street tires, etc?
    I see the 2wd drive runs P215/70R15 and the 4wd is P245/75R16
    what are the reasons for the better mileage on the 2wd?
    thanks!
  2. Sep 14, 2011 at 9:35 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I assume less weight of front diff and transfer case
  3. Sep 14, 2011 at 9:58 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    The reg cab 4X4 has 4.10 gear ratio and the reg cab 4X2 has 3.58 gear ratio.You notice there is only 1 mpg difference for city driving. Running 70 mph the 4X4 with 4.10 gears will be running more rpm.Running around town and rural local roads I don't think you will see a huge difference in mpgs.Maybe 2 mpg.The 4x4 has 16 inch tires and the 4X2 has 15 inch tires.4X4 is a 6 lug wheel and the 4X2 5 lug wheel.
  4. Sep 14, 2011 at 10:15 AM
    WV150
    South Carolina
    Bye the way,just what do you guys with a reg cab 4X4 automatic with the stock 245/75/16 tires get for gas mileage?
