12.5 mpg!
Discussion in 'Performance and Tuning' started by LonghornTaco, Jan 3, 2009.
  1. Jan 3, 2009 at 7:29 AM
    LonghornTaco
    LonghornTaco [OP] Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Now, I'm not a nut for gas mileage. As long as it's decent, I'm ok. But I took a look at my gas mileage from my trip to Texas and back and I averaged 12.5 mpg! I have a tonneau cover and had a couple hundred pounds of stuff in the bed, but I wouldn't think it would be THAT bad! GPS said my average speed was 67 mph over 18 hours and 1200 miles.
    Has my lift and everything else I've done to my truck really done that much to my gas mileage?
  2. Jan 3, 2009 at 7:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Should get better as you get more miles on the engine. Did you correct the milage for the tire size?
  3. Jan 3, 2009 at 7:35 AM
    LonghornTaco
    Minnesota
    Yep. And these numbers are taken from GPS - so, actual speed and distance rather than speedo/odometer. But after the tires, I'm pretty close to right on my speedo - it's about 2-3 mph slow at 65. Was 4-5 mph fast before the tires... :)
  4. Jan 3, 2009 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Exen though your speedo is prety close, the ODO is going to be off. factory speedos are off by 5 mph or so, but the signal from the ECU is pretty accurate. Yes, the same signal goes to the speedo, but the guage it self is inaccurate.
  5. Jan 3, 2009 at 8:05 AM
    tacoma08MZ
    tacoma08MZ Well-Known Member
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    tinted head/tail lights-blacked out badges-3 inch tuff country lift 33 inch nittos-black steelies custom spare bed mount-hilift-weathertechs-kenwood dnx5120 dvdnav headunit-remote start-painted grille surround-fog lights-grillcraft black mesh grille
    I get about that driving back and forth to work everyday, its back roads up and down hills but still, i think i should be getting way better than that. Im gettin about 250 miles to a tank thats horrible and im pretty easy on the pedal :confused:
  6. Jan 3, 2009 at 8:15 AM
    wildtrax1
    wildtrax1 Active Member
    GA
    09 4x4 TRD OffRoad
    I just checked my the mileage for my first tank of gas and got a whopping 12 mpg. I sure hope it improves after break in.
  7. Jan 3, 2009 at 8:18 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    You guys may want to look into an AFR guage. There is a chance that you are running rich, and wasting a lot of fuel. While its unlikely, its a possibility.
  8. Jan 3, 2009 at 8:27 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    What kinda gas are you using?
  9. Jan 3, 2009 at 8:28 AM
    LonghornTaco
    Minnesota
    I'm using just regular unleaded - the cheap stuff. 87 octane
  10. Jan 3, 2009 at 8:30 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    how many miles do you have on your truck?
  11. Jan 3, 2009 at 8:31 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Dang, that sucks. Cruising 80-85 i get 18mpg, and 65-70 closer to 20mpg...
  12. Jan 3, 2009 at 8:32 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Winter fuel blend has extra ethanol in it, correct? Maybe that also helped bring your MPG down. I'm driving back to MD today, so I'll get an MPG and post it for comparison sake.
  13. Jan 3, 2009 at 8:34 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I would guess that you are using winter gas by now. That has been said to drop mileage a few points.
    I get about 20.5 on my commute, but I average about 67mph and have no loading.
  14. Jan 3, 2009 at 8:38 AM
    Oh_Six_Taco_4x4
    Oh_Six_Taco_4x4 Professional High Fiver
    Orange Park, FL
    TRD Sport 4x4
    OEM skid plate. 3" Toytec lift with AAL. Trail Gear Rock Sliders Rechargable Maglite
    Stock, I got like 320-340 out of a tank. After my 3" lift and 265/70/17 mud terrains, I get about 250. :eek: Your not alone!
  15. Jan 3, 2009 at 8:39 AM
    LonghornTaco
    Minnesota
    5500 now.
    I thought I was getting 17-18 mpg during normal driving (commute, etc) but I'm going to pay closer attention to it during this tank. Just curious now!
  16. Jan 3, 2009 at 8:42 AM
    praetor
    praetor Well-Known Member
    Carlsbad, NM
    08 Prerunner Accesscab TRD Off Road
    My last three tanks were. 16.5, 17.3 and 17.6. I have roughly 300-400lbs in the bed and off road quite a bit. I am averaging 1200 miles per week with 700-800 off road. I don't try to get the best mpg and average 80-85 on the highway. I am also using 91 octane.
  17. Jan 3, 2009 at 8:49 AM
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    My first tank was 16 MPG, at 8000 miles or so combo HWY/city 18 MPG. I picked up a Undercover tonneau cover so i'm going to check it again.
    My freind says Mythbusters show showed trucks get less MPG with them. I think the cover will not make a dif. I think with the tailgate removed the MPG might drop off a little.
  18. Jan 3, 2009 at 8:51 AM
    tacoma08MZ
    Levi
    Pittsburgh, PA
    2008 Access Cab 4x4
    i have just about 7000 miles on mine and ive been running 93 octane
  19. Jan 3, 2009 at 9:42 AM
    sonjay
    sonjay Well-Known Member
    What was the temperature during your trip? Cold weather lowers fuel economy.
  20. Jan 3, 2009 at 9:47 AM
    Mr.Ed
    Wilbur's Barn
    It must be the lift & tires.
    Dude just checked out your Pick's nice truck clean & mean looking, also the lady WOW!
