12.5" wide tires on 8" wide rim???
Discussion in 'Wheels & Tires' started by pyroskier, Oct 10, 2011.
  1. Oct 10, 2011 at 1:07 PM
    pyroskier
    pyroskier [OP] Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    Hey guys, can you (eh... is it safe to) run a 12.5" wide tire (33x12.5x15 Duratracs) on a 8" (15x8 Granite Alloy GA9) rim? I've seen some people with it, but it just seems scary. Opinions? Fast would be nice, I'm planning on ordering them tonight.
  2. Oct 10, 2011 at 1:30 PM
    pyroskier
    Jacob
    Laramie, WY
    Bump for help!
  3. Oct 10, 2011 at 1:31 PM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    Plenty of guys do it. Should be no problem.
  4. Oct 10, 2011 at 1:38 PM
    Catcrazed
    Catcrazed Save a horse ride a Railroader
    Bryan
    NW Oregon
    91 Flatbed 3.4
    91 Toy flatbed,4.88's ARB,285's,3.4 V-6 Swap
    Scary? All that would happen is the tire will wear in the center more.
  5. Oct 10, 2011 at 6:19 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    Thats what Im running. Im still alive
  6. Oct 10, 2011 at 6:28 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    ya its safe, id prefer myself to run a 9" on that setup but it will work
  7. Oct 10, 2011 at 6:30 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    im 12.3" wide on 8". absolutely no problems
  8. Oct 10, 2011 at 6:36 PM
    sander1036
    sander1036 Well-Known Member
    Snack Food Capital of the World
    02 SR5 TRD Double Cab 4x4
    THULE Roof Rack, Color matched grille w/ GrilleCraft, Toytec Ultimate, 33 x 12.5 Duratracs, Bushwacker Cut Out Flares, Cvt Mt Shasta, Cvt Awning, LEER Cap
    im perfectly fine same rims same tires... and like cat crazed said theyll just wear in the center more, i aired down to 30 lbs i think and about a 1/2" of tread on the outside of the tire is not quite touching road surface
  9. Oct 10, 2011 at 6:42 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    33x12.50 on 15x8 is what I'm running. I run my tires at lower PSI to compensate for the arch created by the 8" wheels. No problems!
